Xenon Headlight Adjustment
My Ride: 2007 BMW 550i Sport Pkg, 6MT
If you feel your Xenon headlight low beam is a bit too low, here is how to adjust:
1. Find BMW screwdriver in the first aid kit
2. Find vertical adjustment screw for each Xenon headlight.
3. Adjust vertical adjustment screw on each side.
Do not exceed 1 full turn or you will blind other drivers.
Note: Lateral adjustments are usually not necessary.
- Clock wise: down
- Anti-clock wise: up.
or if you lost/forget the default alignment, this link will help to have a perfect aiming of the headlights:
http://www.danielsternlighting.com/tech/aim/aim.html
Originally Posted by Almighty JungleBoy' post='395339' date='Feb 25 2007, 05:48 AM
Thanks hmc!!
Just curious, is there a way to adjust the brightness of the angel eyes rings? anything to turn for those?
Thanks!!
Thanks!!
My Ride: 2005 545i Black on Black, Auto, Premium, Sport, Dynamic Drive, Nav
+1 - I have used this method with great success on my 03 X5 and on my 545
