WinKFP help please
My Ride: 2012 535i M-Sport
So just like NCS and INPA - I read the internet for days and hours - and after some great advice and a few mistakes I got it. WinKFP information is a tad more elusive and obscure. I get the gist of what to do once I have my ZUSB number and the workings of 'comfort mode' - but getting to that point is just not happening for me. I have tried following the PDF on how to start using WinKFP - and I do the assembly line data import (One board said to do ECU data too, so I did that) it seems to import because the progress bar goes to 100% - but when I enter my VIN and ZUSB it tells me there is no data for such a module and when I go to the ZUSB list it is empty, so obviously I am not importing data correctly - OR - I am importing the wrong data. I have the latest DATEN files and everything else under EDIABAS seems to work....just not this.
So is there a chance that an expert in this field that is not yet tired of answering these questions could point me in the right direction?
I have searched and read every related post (that I know of) on this forum, bimmerforums, bmwcoding, bimmerretrofit, ecubb, and other Russian sites (found in Google) and I am just not getting it...
All I am trying to do this time is update CGATE so I can use CIC controller with pre-LCI retrofitted CCC.
Thanks!
Thanks!
Engine: N54
Hey Chase,
I got everything I needed to out of that how_to_start_winkfp.pdf to make mine work.
My version is 5.1.6 and the NFS folder has 2,170 files and size on disk is 4.62 GB (4,967,452,672 bytes)
Jim
Jim
I did copy over gdaten yes, but the files I have are MUCH smaller than what you mention Jim - so this is where I went wrong. I will start fresh with a clean install and follow the PDF to the letter - I am sure this is what I am doing wrong.
Thanks guys!!
EDIT: In the 'how to start' PDF it mentions file names called SD-DATEN, I have no such directory. I will keep trying.
Thanks guys!!
When following that guide, just do the E60 car. Don't bother about all the other cars.
Thanks for your help guys . I managed to figure it all out....
I updated the CGATE then my iDrive low controller stopped working - the menu button too. It gave me a good scare - so I messaged NoQuarter for advice and he assured me it was fine.
So today I ripped the center console out and did some dremel hacking. I thought I blew it a few times because cutting is scary on these cars.
But in the end the CIC controller is in and functioning perfectly.
I do believe that will be my last experience with WinKFP, too nerve racking. Whoever buys this car will have a mystery on their hands as to why the controller is so new but nav is so old.
BMW did actually produce a run of these cars with the CIC controller but with the CCC (LCI version ofcourse).
Engine: N54
Glad you got it going Chase. Well done!
wokingBigBoy
Feb 11, 2018 07:56 PM
