What power supply do you recommend for programming/coding?
Hi Gents,
I found a couple of recommendation from bimmersforum, but might be too weak or overkill for our E60 task. What's your recommendation and model you're using?
Thanks,
Fred
Thanks,
Fred
Engine: N54
I probably should be using something better but I have been getting by with a 6 amp "smart" kind of charger. The 6 amps can barely keep up if I am doing a lot of light stuff but if I limit myself I can do what I want and then I just leave it connected until it shows a full charge. After you get past the initial "learning" stage and changing the popular items, there isn't a whole lot left to do other than experimenting in trying to get something to work that hasn't been validated and posted by someone else.
Model Year: 2005
Engine: 545i
Bank$hot530
07-12-2015 04:36 PM
