Unlocking the E60 Hidden OBC Menu (instructions)
Old Dec 22, 2010 | 02:40 PM
AchtungE60's Avatar
My Ride: E60 530i
I was cleaning up some folders and found this. Not sure if it's posted here or not. If so, sorry for additional post. But as we know it can be tedious to find buried info.
All credit due to M5 board member "scoopz"
I am not sure if it works on all clusters.
This menu will allow you to check some useful features such as:
battery voltage
Instrument test
engine Revs per min.
coolant temp
audio test
Many other things.
E60_Hidden_OBC_Instructions.pdf
Old Apr 29, 2011 | 05:57 AM
Georgieb's Avatar
My Ride: 2007 Black Sapphire 535i
I searched high and low for this earlier. Thanks!
Here's the forum link. Credit goes to Scoopz.
http://www.m5board.com/vbulletin/e60...-obc-menu.html
Old Apr 29, 2011 | 06:05 AM
Georgieb's Avatar
And in a somewhat related bit: How do you reset service light bmw e60?
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
Source(s):
BMW Mechanic I employ
Old Jun 30, 2011 | 08:57 AM
ian_alex's Avatar
I've been trying to check out the service reset procedure with no success, I can't get past the service triangle stage which simply disappears when I release the odometer button to move it to the various specific service items.
The service triangle with included exclamation mark is red not yellow by the way!
What am I doing wrong??
I can read the many detailed German codes OK, these are interesting but not of practical use as far as I can see.
My car is a UK spec 2008 520d touring.
Any assistance would be appreciated.
Old Jul 1, 2011 | 07:01 PM
Georgieb's Avatar
ian_alex,
Did you ensure you set the odometer trip meter back to zero before trying to get into the service menu. This happened to me also the first time a tried to accomplish this.
Let us know.
Old Aug 11, 2011 | 01:53 PM
Stephen Max's Avatar
My Ride: 2004 545i Sport 1998 M3
Thanks for the info.
//M
sfcacique
Aug 25, 2025 06:56 AM
rackhacker9275
26
Apr 16, 2015 08:13 AM
BYS2
Mar 30, 2015 05:33 AM
ZeZe
Oct 15, 2003 12:58 PM
