Tweeter replacement
Any write up on the process of removing the door card?
Originally Posted by BLooD' post='1002640' date='Sep 9 2009, 08:29 AM
you need to remove the door card then pull off the plastic trim covering the tweeter, make sure to disconect the battery before you disconect the airbag
My Ride: BMW e61 2006 520d, chiptuned to 180 hp.
18" 124's
can anyone tell or describe how to mount new tweeters? I read in this topic to remove the doorcard, and disconnecting an airbag. Then I get a little bit nervous doing this, without having a good description.
So any help is welcome.
look for topic on trim replacement or m5 mirror swaps, you will find what you need.
18" 124's
Thanks for your help. This is really a lot clearer now.
I will be able to mount the new tweeters. Very curious about improvement of high tones.
Cheers,
RIk
Cheers,
RIk
socale39
Sep 5, 2023 08:30 AM
