9) There were about 4 Liters and 100ml of tranny fluid drained out of the hole.
https://i136.photobucket.com/albums/...e/IMG_1043.jpg The color of the old fluid is about "tea brown" color. https://i136.photobucket.com/albums/...e/IMG_1044.jpg 10) The old drain plug was reused. It has the max. torque value on the plug - 8Nm. I used a little bit more than 7Nm to screw the plug back. I have a spare one ready just in case I overtightened it and break the plastic. The fill plug is also hex. I tried 7mm, too small. Then I tried 10mm, too big !!! I am going to get 8mm and 9mm and then start to fill in fresh tranny fluid. That will be tomorrow morning - part 4. :cool: |
Nice write-up dude but you should have kept it all in 1 thread.
Originally Posted by zerocool' post='816628' date='Mar 14 2009, 01:57 PM
+1
Thanks for documenting this. Nice work! :thumbsup:
Waiting for part4!
What fluid you will use? |
Originally Posted by vesil' post='816679' date='Mar 14 2009, 02:58 PM
Waiting for part4!
surprised how the pan bolts have surface rust on them.
Waiting for part4!
