Tore the rubber seal on top of the door... What now?
Old 07-14-2009 | 07:56 AM
vincetampa's Avatar
Thumbs up
Hi all,
Please see the pics below. A neighbor kid shut the door while her umbrella was still out and it tore the rubber seal.
Is there a DIY that is recommended for this? Or, a replacement part? Trip to the dealer $$?
Any help, links or info is appreciated.
-Vince
Old 07-14-2009 | 07:58 AM
Krozi's Avatar
Make the neighbor pay for it
I think you need a new seal...
Old 07-14-2009 | 08:04 AM
theXman's Avatar
My Ride: 2004 530i
It's very simple to replace the door seal. Contact Garry at Newport BMW, you get 25% discount for being E60.net member.
Old 07-14-2009 | 08:08 AM
vincetampa's Avatar
They did offer. But, they're really hurting for money now. I'm hoping to find an fix that's nearly invisible. :-)
No missing pieces, and it does fit back together nice.
Old 07-14-2009 | 08:13 AM
theXman's Avatar
My Ride: 2004 530i
Here are the part numbers for '04
05 Gasket, door joint, roof, door rear left 1 51227057509 $82.01
05 Gasket, door joint, roof, door rear rght 1 51227057510 $82.01
You can do a search in realoem.com for your specific model.
Attached Thumbnails Tore the rubber seal on top of the door... What now?-176.png
Old 07-14-2009 | 08:21 AM
vincetampa's Avatar
thx xman
Old 07-14-2009 | 09:48 AM
flyingpuck's Avatar
Try crazy glue if it's such a clean tear, it might just do the trick and save you some $$$! If not, you could always repair it then!
Old 07-14-2009 | 09:51 AM
Krozi's Avatar
I don't know about that... Since the tear is at the top of the door, I wouldn't risk it now with the summer rain in Florida.
+1 for Gary!
Old 07-14-2009 | 10:13 AM
CWS530's Avatar
+1 for Gary!
How about a bicycle tire patch kit. Cut the rubber to fit over the tear, then apply the adhesive? Anyone?
Works on my Gary Fisher.
Old 07-14-2009 | 11:49 AM
kaiten408's Avatar
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
I like the tire patch idea; look for some sort of rubber glue that will provide a water-tight seal. It'll probably work for a while, but you will have to eventually replace it.
