Hi all,
Please see the pics below. A neighbor kid shut the door while her umbrella was still out and it tore the rubber seal. Is there a DIY that is recommended for this? Or, a replacement part? Trip to the dealer $$? Any help, links or info is appreciated. http://vindavi.com/5/doorphoto1.jpg http://vindavi.com/5/doorphoto2.jpg -Vince |
Make the neighbor pay for it :P
I think you need a new seal... |
It's very simple to replace the door seal. Contact Garry at Newport BMW, you get 25% discount for being E60.net member.
I think you need a new seal... No missing pieces, and it does fit back together nice. |
1 Attachment(s)
Here are the part numbers for '04
05 Gasket, door joint, roof, door rear left 1 51227057509 $82.01 05 Gasket, door joint, roof, door rear rght 1 51227057510 $82.01 You can do a search in realoem.com for your specific model. |
thx xman
Try crazy glue if it's such a clean tear, it might just do the trick and save you some $$$! :geek: If not, you could always repair it then! :cool:
+1 for Gary! |
Originally Posted by Krozi' post='941881' date='Jul 14 2009, 11:51 AM
I don't know about that... Since the tear is at the top of the door, I wouldn't risk it now with the summer rain in Florida.
+1 for Gary! Works on my Gary Fisher. |
I like the tire patch idea; look for some sort of rubber glue that will provide a water-tight seal. It'll probably work for a while, but you will have to eventually replace it.
