Suitable PSU for programming ?
Old Mar 31, 2013 | 04:18 PM
wokingBigBoy's Avatar
Smile Suitable PSU for programming ?
I have seen this psu priced reasonably:
PS600ADJ - FUSION 600W / 40A ADJUSTABLE POWER SUPPLY
O-FS-PS600ADJ - FUSION 600W / 40A ADJUSTABLE POWER SUPPLY
It is 13.8v 40A.
Will it do the job for programming - WinFKP.
Thanks
Old Mar 31, 2013 | 06:43 PM
Gee_115's Avatar
My Ride: 07 550i Sports Package
I usually just hook up my other car using jumper cables. Just make sure you have enough gas if you are doing something that will take a while to complete.
Old Apr 1, 2013 | 12:02 AM
The CCC takes about 4Hrs so really need a PSU.
Thanks
Old Apr 3, 2013 | 05:35 PM
Gee_115's Avatar
Actually if you are coding the entire CCC it will take longer than that with OBD, someone mentioned 10hrs. Also, coding the CCC over an OBD connection is not recommended, many have encountered problems because of the slow connection. If you are going to code the CCC you should do it through the MOST connection with OPS or INPA.
Old Apr 17, 2013 | 12:49 PM
I have seen a video on YouTube of a guy doing this via a DVD, but cant find how to make this, unique DVD with your VIN.
Bogdan7
Sep 23, 2015 11:40 AM
ey2001
Sep 13, 2015 03:25 PM
ucsbwsr
20
Sep 8, 2015 08:30 AM
jhawk19
Sep 7, 2015 12:11 PM
hmilycar
E39 Discussion
Aug 25, 2015 10:44 PM
