Squeaky windows Cure ???
Location: Auckland New Zealand Home of Lord of the Rings
My Ride: 2004 E60 545i motorsport,,retired ACS E39 2000 520i 2.2, E46 2001 motorsport sedan mine but son's drive, E46 2001 motorsport coupe, and just retired Porsche Cayenne Turbo.
For playn 2007 E92 335i motorsport little brother of my 545i in Alpine white also...faster than my Porsche Cayenne Tirbo and alot more fun..
Hi
My E60 2004 Motorsport has squeaky windows while driving, any small bump and you hear it.
However put them all down a 1mm and noise totally disappears. The front are worse than the rear...
Tried the vasline on the door seals first but its not that.
It sounds like when the window is up tight the internal window tracks load up causing the squeak...
Anyone else found a cure ...Please
Cheers
Cheers
I should have googled the problem first....now solved ...Yes I used Vaseline but on the door seals ...wrong...only when I applied to the felt edge ...as was suggested in the forum...all noise now gone ....What a great site for information ...I now can see how Vaseline on babies bums stops them squeeling also..Cheers
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
