Sprint Booster Problem
Hi guys:
I bought a sprint booster for my 04 545i auto. But the first time I install it, it shows engine malfunction and cruise control disable. So I took it off and the problem goes away. I checked the pins and reinstall the SB, and it seems to work well. But after about 70 miles, when I was driving on the highway, the same problem occurred, and the computer forced a reduction in engine power. Anyone knows what is going on? Thanks very much.
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Originally Posted by jaybas104' post='562438' date='Apr 16 2008, 04:45 PM
Hi guys:
Try look on bended pin in your SB cos they do cause the problem sometime, and make sure you install in the right way (see the numbers on the SB and your car's socket)
first time ive heard of a cruise control error. the pins have been the most common problem with the sprintbooster i think. you could check the parts mods section and e60 discussion. there are numerous discussions on the sb.
welcome and enjoy the forums.
My Ride: 2004 E60 Bi-Fuel
Business Navigation
Park distance control
Sunroof
extended airco with armrest
18" M5 rims with Runflats
xbox with 2 headrests LCD
front LCD video enabled
Detachable towbar
Alarm
anti-blind rearview mirror
Adaptive Xenon
Bluetooth carkit
Garage door opener integrated
Headlight cleaning system
Seat heating front
I had the same problems, but I don't have a sprintbooster installed
My problem was that the battery was bad.
The e60 doesn't notify you that the battery is bad, starting goes OK, but cruisecontrol gives an error while driving and while the cruise control wasn't activated.
A few seconds later an engine malfunction will be reported.
My battery died after 2 years
Justin
Justin
Originally Posted by jaybas104' post='562438' date='Apr 16 2008, 11:45 AM
Hi guys:
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Make sure the #'s are in the correct order, and make sure you push the connector all the way in . Some time people have had issues with it not being plugged in all the way, # not matching up ( basicly the SB is installed up side down), or a bent pin.
thesalboy
04-08-2015 09:13 AM
