Sprint Booster - Error Message & Engine Light on
My Ride: 2007 E60 550i - Titanium Silver, Dakota Black, STEP, Sport, Premium Sound, NAV, SAT, PDC, Logic 7 and Shades. MODS- K&N, OEM 166M's
I have a 2007 550i automatic and I installed the Sprint Booster last weekend. As soon as I started the car, it chugged a few times and the the engine light came on saying "have engine serviced soon" and that the car would operate with reduced power. When I removed the SB, the light stayed on and I had to take the car into the dealer to have the light re-set.
I followed the install instructions and I have the correct SB made for automatics. Has anyone experienced this problem?
Thanks
Thanks
Did you try the reset?
Search the forum for 25 second reset. That should do it I hope.
Tonymac
Tonymac
+1 for the reset, some members have reported the same problem...just gotta drive it around for a little bit..
check this thread...
http://forums.e60.net/index.php?showtopic=58392&hl=
Tonymac
Tonymac
Thanks.
Originally Posted by howser' post='744106' date='Dec 12 2008, 01:13 PM
No I did not try the 25 second re-set. I'll do a search and see what I find.
Thanks.
Thanks.
My Ride: 2004 545i SGM Steptronic Dinan CAI Dinan TB GTech Pro RR
Thanks
Thanks
Originally Posted by brandsb' post='744214' date='Dec 12 2008, 08:31 PM
Sounds like you have the plug connected wrong. The same thing happened when I installed mine; found out I had the connector plugged in wrong.....rotated 180 degrees and it solved the problem.
+1
I will give that a try.
Thanks brandsb
Originally Posted by howser' post='744924' date='Dec 14 2008, 10:40 AM
+1
Thanks brandsb
Thanks brandsb
Does the SB effect your warranty status? when you bring your car to the dealer for service, do they notice it? if yes, do they say anything about any warranty issue?
thanks.
thanks.
