Sprint Booster DIY
#31
My Ride: 5series
Hey guys... will this sprintbooster work for manual 6spd "stick shift", and if it does will I notice any difference in throttle response & gear shifting?
thnx
#32
My Ride: 5series
Help i plugged the sprintbooster in but i dont know where to place it behind the pedal in order for a secure fit.pls. help me thnx.
#33
My Ride: 2004 545i SGM Steptronic Dinan CAI Dinan TB GTech Pro RR
#34
My Ride: .
Model Year: .
Originally Posted by brandsb' post='473145' date='Sep 22 2007, 03:02 PM
Place it beside the pedal, not behind it. I found a little recess in the side of the pedal housing that accommodates the SB housing to some degree. It allows the accelerator housing to be mounted to the floor but you can still see the orange SB cable when you look down in the footwell. It's not perfect but the SB results will quickly make you forget it.
-thanks
#35
My Ride: .
Model Year: .
Nevermind... took a bit more work, but I got the SB body connection back behind the carpet. I had to cut the carpet open a bit more to make it fit. I personally like a cleaner look. You can't see a thing in the footwell, not even the wires, you'd have to stick your head down there and know to look for the wire.
I looove it, almost scary.
timmay77
09-23-2015 12:34 AM
E61mendo
09-15-2015 03:55 AM
spediegunz
08-30-2015 09:43 AM
