Springs on a 545i
Old 08-20-2010, 12:04 PM
nonford's Avatar
My Ride: 2011 Lexus IS-F
Originally Posted by salaki
I never tried or came across anyone w/ Bavarian's springs but those are great deals for sure considering Bilstein SP is around $ 612 a set shipped.
Check w/ Bavarian to find out more about their spring more.
Ask them how does it compare to OEM Non Sport and OEM Sport Suspension and other brands (like Eibach Sportline/H&R Sport)
I was just wondering if Bavarian's springs are actually a re badged Eibach/H&R w/ similar spec but marketed as Bavarian spring.
Thanks! Yep, I believe its a rebadge of H&R and the price is what is persuading me. I will be calling them to make sure. They have always been great to deal with..
Old 08-20-2010, 12:29 PM
salaki's Avatar
My Ride: 05 545i 6MT
Got some PDF for ya from the TIS
Not much detailed pics compared to Bentley manual.
Old 08-20-2010, 02:14 PM
Defy's Avatar
My Ride: 05 545i loaded!
WOW! Thanks!!!!
Old 08-21-2010, 06:52 AM
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
that reiger kit is gonna be sitting on the ground gonna look sick but scary to drive
Old 08-21-2010, 09:17 AM
salaki's Avatar
My scanner is acting up. Looks like the USB port is broken or something. Can't recognize it.
Looked around the Bentley manuals.
It seemed that they are pretty much the same w/ the TIS PDF so please just use that.
One trick I learned yesterday when I was working on the arms in relation to working on spring install.
If you LOOSEN the control arms bolts that bolt into the frame, the hub is super loose to push down for strut removal clearance.
So you will be able to get away from having to remove all the control arm ball joints from the front knuckle.
jrmccain
11-04-2015 05:16 PM
javaco888
09-30-2015 08:02 AM
subieworx
09-13-2015 11:02 PM
KyleB
09-11-2015 05:00 PM
rmendoza.2611
09-11-2015 10:00 AM
Quick Reply: Springs on a 545i
