Sirius install DIY?
Hi,
My post-DME install 545 is now at my dealer, ready for pickup. The Sirius option was changed from factory to dealer-installed between the time I ordered the car and when it was produced. Now, the dealer wants $950 to install it, rather than the original $595.
I see that Circle BMW has the parts for about $350, but I can't find any installation instructions. Has anyone done this? I assume the receiver's easy to install, but that programming would be necessary afterwards, like the phone.
Any insight? Thanks
Any insight? Thanks
My Ride: E90 M3
Model Year: 2011
$950!!!! That is a rip off! The parts are about $350 and the official BMW line is 1 hour of labor for install. I'd check at another dealer if there is one in the area.
My Ride: 2004 545i Silver Gray/Black
Step Auto. Sports Package, Logic 7, Cold Weather Package, Parking Distance, and Rear Sun Shades
2002 330ci Titanium Silver/Gray
Step Auto, Sports Package, Premium Package, Xenon, 18 inch wheels.
Not sure if that can be DIY. You may still need dealer to enaable sirius radio in iDrive software setting.
My Ride: E90 M3
Model Year: 2011
bmw545 is right, it is not just a matter of plugging in the module, there is some software work that the dealer has to do. But again, I was show the actual BMW memo at my dealer describing the parts needed and the cost and it clearly showed to charge 1 hr of labor. Unless the going rate in N. Ca. is $600/hr for labor, I'd shop around.
From what I understand, you need to have the factory install the Sirius radio antenna in your sharkfin (satellite radio prep). I think they charge $75 for this if you have nav. If you don't have the factory prep, I have heard that you need to install an antenna in a pod on your trunk.
I'm getting this info thirdhand, so you definitely should check - especially if they are going to install something onto your trunklid.
$950 is definitely a ripoff - I paid $595 for the entire thing. It is fantastic - I highly reccomend it.
Thanks for all the feedback. I asked them to stick to the $595 factory charge, but they're just saying "it's more now." You know the game.
In any case, the option isn't in the 'build your BMW' site anymore, so there's nothing to compare to.
I did have the sat radio prep done, so that's a start. I'll see what the other locals are charging.
Originally Posted by tjohnson' date='Dec 29 2004, 07:27 PM
john W-wanted an update did you go the dealer route or get the parts from circle bmw?
[snapback]73599[/snapback]
snaprolll
DIY: Do It Yourself
05-05-2015 05:09 PM
