Silver Steering Wheel Trim ...
Old 03-20-2005, 12:53 AM
MEX
MEX's Avatar
how do i know if i have the polygon airbag or the round airbag? i have the standard steering wheel.
Old 03-20-2005, 03:25 AM
Hobi's Avatar
My Ride: 2005 MY 545i Sport Saloon. 2006 MY Alpina B3S Convertible. 2006 MY Brabus Smart 42 Cabrio. 2006 MY AM DB9 Coupe.
[snapback]104027[/snapback]
Hi Mex
This is the round airbag:
All the Best
Hobi
Old 03-20-2005, 05:31 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by Hobi' date='Mar 20 2005, 07:25 AM
[quote name='MEX' date='Mar 20 2005, 09:53 AM']how do i know if i have the polygon airbag or the round airbag? i have the standard steering wheel.
Hi Mex
All the Best
Hobi
[snapback]104043[/snapback]
[/quote]
Hobi,
I received the trim pieces on last Friday. It came with 6 small black colour screws. When I looked at the silver trim pieces, it had 2 holes in the bottom and a clip too. So, I assume that each trim piece needs 2 small black colour screws. There are 2 extra spare screws ....
I will install it when the weather is getting warmer in Boston. Spring just arrived today. Regarding to the airbag, should I install it back to the steering wheel and turn the key to II position before reconnect the battery negative terminal ?? This practice is used in Volvo steering wheel airbag installation to make sure airbag doesn't deploly accidantally. The airbag warning light would not come on, right ??
Since you mentioned that we should disconnect the airbag on the steering wheel side, why we should not disconnect the airbag on the airbag side ?
Thanks,
Ching-Ho Cheng
Old 03-21-2005, 01:17 AM
Hobi's Avatar
Hi Ching
Whatever you do, make sure every connector in the steering wheel (inc airbag) is all connected up and airbag secured in teh wheel BEFORE connecting the battery!!!!
With BMW, if you reconnect the battery and the airbag is NOT connected, you will get the "airbag faulty red light" in the dashboard display.
Make sure the key is NOT in the ignition at all when you reconnect the battery.
Connectors:
The reason why I suggest that you disconnect the airbag from the wheel using the connector on the wheel side is that it is just ONE connector block - whereas if you disconnect the connectors on the airbag itself, you will need to detach THREE connectors. Besides, the 3 airbag connectors are more fragile than the big multiblock connector on the wheel side!
Do you want me to place a couple of images of the airbag connectors etc. here for you???
All the Best
Hobi
Old 03-21-2005, 04:47 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by Hobi' date='Mar 21 2005, 05:17 AM
Hi Ching
Connectors:
The reason why I suggest that you disconnect the airbag from the wheel using the connector on the wheel side is that it is just ONE connector block - whereas if you disconnect the connectors on the airbag itself, you will need to detach THREE connectors.? Besides, the 3 airbag connectors are more fragile than the big multiblock connector on the wheel side!
All the Best
Hobi
[snapback]104439[/snapback]
Hobi,
Thanks for the explanation!!! If you don't mind, I would like to see some pictures about the airbag connectors. That will be very helpful to me that I know what to deal with once I pop out the airbag.
Thanks,
Ching-Ho Cheng
Old 03-21-2005, 05:20 AM
Hobi's Avatar
Hi Ching
OK... in a couple of hours they'll be here.
All the Best
Hobi
Old 03-21-2005, 07:02 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by Hobi' date='Mar 21 2005, 09:20 AM
Hi Ching
OK...? in a couple of hours they'll be here.
All the Best
Hobi
[snapback]104502[/snapback]
Thanks,
Ching-Ho Cheng
Old 03-21-2005, 08:03 AM
Harry's Avatar
My Ride: BMW E60 9/04 BMW E46 / 3
Originally Posted by Iceman' date='Mar 11 2005, 12:16 AM
[quote name='Hobi' date='Mar 10 2005, 11:33 PM']As always, Iceman is correct...!!
[snapback]99725[/snapback]
Not allways.
I wish it was allways, Saturdays Lottery jackpot is 21 Million Euro...
[snapback]99753[/snapback]
[/quote]
Lottery? What for man? "looking at your signature"
Old 03-21-2005, 09:47 AM
Hobi's Avatar
Hi Ching
Here are 4 images:
This one shows the 4 clips that hold the airbag to the internal metal frame of the wheel. You can see the trajectory of the screwdriver that you have to insert to push against the horizontal metal clip that forms the 4 retaining clips. Basically, when you press the screwdriver against the it, the clip bends inwards on both sides and thus releases the airbag from the wheel. The ECU is in the bottom "spoke".
Top down view of the ECU. To the right of it is where the multiblock airbag connector plugs in. It is held by one retaining lug that you have to push together and then the connector pulls out vertically. Next image will show you the connector.
The airbag connector with the plastic lug on the front of the connector.
Now you see why I suggest to disconnect the ONE connector and not the three on the airbag itself! The Green and Black plugs at the centre are fixed securely and should not be released at all. The connector marked "fragile" is for the horn switch. It is attached to a sort of ribbon cable and it's not worth undoing this connector.
You should be able to detach the airbag from the wheel without having to detach the cable from the clamp on the back of the airbag.
Hope all this helps. Much easier 'done' than said I think...
All the Best
Hobi
Old 03-21-2005, 10:59 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
[snapback]104575[/snapback]
Yeah, but the car is lease through my travel agency...
Quick Reply: Silver Steering Wheel Trim ...
