Side gills on e60 M5
Old 12-17-2006, 07:18 PM
m500hp's Avatar
Does anyone know how to remove the side gills on the E60 M5? I just purchased new side gills in CF and I have no clue on removing the stock ones.
Old 12-18-2006, 01:30 AM
Dav530d's Avatar
I'm not sure about M5 but have done this with M pack side skirts which I believe are the same.
Unscrew all the plastic fixing from along the underside of the skirts,
unscrew 2X 8mm bolt screws at the front just under the wheel arch and the same at the back,
Open the doors and the pull the skirt hard, (it's held in with plastic clips)
I know it's a bit vague but hope it helps.
Old 12-18-2006, 09:57 AM
my530i's Avatar
It's side gills on the fender. Not side skirt.
Old 12-18-2006, 06:05 PM
m500hp's Avatar
Thanks my530i for the clarification . Yes it's on the m5, so it's the side gills on the fender, not the side skirt. Thanks for trying Dav530d.
Old 12-19-2006, 05:59 AM
vl20sas's Avatar
My Ride: bmw 530d,2004,500nm,navi profesional.bi-xenon ,adaptive curve light,active sterring,etc...
1.first of all,you need to remove fender from car
2.side grills have 4 clips
3.press clips one by one
here are some pictures
Attached Thumbnails Side gills on e60 M5-dsc00713.jpg   Side gills on e60 M5-dsc00714.jpg   Side gills on e60 M5-dsc00715.jpg   Side gills on e60 M5-dsc00718.jpg
Old 05-27-2007, 12:00 PM
coolguy's Avatar
My Ride: 2006 525i, Premium,Cold,Xenon Packages
Is it possible to install these on Non-M5? offcourse with out the M5 sticker.
Old 05-28-2007, 08:01 AM
my530i's Avatar
Yes. Check with quan717 who used dremmel to cut his fender and fit on "aftermarket" gills from ebay.
Old 05-28-2007, 06:22 PM
pinguhk's Avatar
My Ride: Mini Cooper
100% yes it will work, I have seen a car with them on in HK
but you will need a bodywork shop to cut out the hole.
Old 05-28-2007, 07:03 PM
coolguy's Avatar
a hole? It looks like a big section needs to be cut out from the fender right?
These things has a block on them to place the M sticker.. I wonder if I can buy grills w/o the Sticker holder.
Old 05-28-2007, 07:51 PM
pinguhk's Avatar
OK a big hole
Quick Reply: Side gills on e60 M5
