Securing items in the trunk....an easy DIY
Old 05-24-2004, 10:59 AM
Jimbo's Avatar
As we all know the E60 trunk is huge so to keeping things from moving around usually means buying a cargo net.
The nets I've seen did not appear adequate because they did not cover the entire trunk floor and would not hold the big size items that the trunk is capable of carrying. So this got me to thinkin'.
After studying the inside of the trunk for awhile I noticed some holes that were big enough to hold a hook. Remembering all the tie-downs and bungi cords I purchased when moving my daughter in/out of her college dorm, I searched a bit in the garage and began tinkering.
I did find two holes under the rear window deck on the right and left sides that had some vinyl plugs in them and were easy to remove.
All the straps are easily removed or repositioned if necessary. If you don't need to use the straps on the bottom, just set what every you're carrying right on top of them.
My install looks kinda crazy because of all the different colors but since no one sees it, who cares. The price was right and it works and works well.
Attached Thumbnails Securing items in the trunk....an easy DIY-trunk_view.jpg
Old 05-24-2004, 11:01 AM
Jimbo's Avatar
more pics
Attached Thumbnails Securing items in the trunk....an easy DIY-trunk_box_tie_down.jpg
Old 05-24-2004, 11:02 AM
Jimbo's Avatar
more
Attached Thumbnails Securing items in the trunk....an easy DIY-trunk_hooks.jpg
Old 05-24-2004, 11:03 AM
Jimbo's Avatar
more
Attached Thumbnails Securing items in the trunk....an easy DIY-trunk_hooks1.jpg
Old 05-24-2004, 11:04 AM
Jimbo's Avatar
last one
Attached Thumbnails Securing items in the trunk....an easy DIY-trunk_hooks2.jpg
Old 05-24-2004, 11:39 AM
JDN
JDN's Avatar
Thanks, Jimbo. I use something very similar - strong rubber straps of varying lengths with hooks that I pick up from Great Northern Tool and Equipment or similar store. Works better than it looks.
Old 05-24-2004, 12:27 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Nice job! All you need to do now is flip over the mat and you'll have a non-skid surface to add to the security of your "net".
Old 05-24-2004, 12:59 PM
Jimbo's Avatar
I read your post. I'll give it a try.
Thanks, Rudy.
Old 05-24-2004, 01:09 PM
duke's Avatar
Looks good, I bought two plastic containers from target that fit side by side and are the width of the trunk. Push them up against the back seats & then use bungies to hold them in place.
Great for groceries and anything that will fit in the containers.
Old 08-01-2004, 12:38 PM
JDN
JDN's Avatar
Here is my solution using four very stout straps. I have found that I can haul everything from a gallon of milk, lawnmower gas can (full), gun box, brief case, laptop, or whatever. If I can't just position it under the four strap arrangement, I can unhook and stretch the straps over.
Once tied down like that, I can drive any old way I want to without worrying about the load in the trunk.
Quick Reply: Securing items in the trunk....an easy DIY
