Salvage E60 545i Rebuild
Originally Posted by 2exclusive' post='1005583' date='Sep 12 2009, 11:51 AM
have you heard of the peake tool... http://www.peakeresearch.com/ it cost about 150.00 on ebay and it will reset the codes guaranteed. what do you think about it???
Peak tool only clears out engine error code such as engine service soon..
I don't think it would work ... 7g obd 2 reader couldn't clear it out
Originally Posted by brianyo' post='1005939' date='Sep 12 2009, 11:48 PM
Sometimes after an accident the seatbelt sensor gets pulled along with the seat belt... Not 100% sure, but at the bottom of the seat belt (the panel on the floor has to come off) there is a big round torx head screw and if that metal clip holding the seatbelt in place is bent in any directions besides perfectly parallel to the top of the seatbelt where the clip on the roof holds it in, it might give you and error.
just changed my seats in my 545i to comfort seats from a wrecked 550i if the airbags went off you need to change out the seatbelt pretensioners (they will be kinked if there shot i can send you a pic of what a bad one look like)move the seat all the way forward and theres one Torx 50 bolt holding it in
and then take it to the dealer and have the SRS codes cleared
Originally Posted by HaroutK' post='1014379' date='Sep 22 2009, 08:34 PM
junkyards also try the bt scanner burgermotorsports.com
so i got both seatbelt pretensioners from a dismantler and the guy at the shop is going to charge me 250.00 to change both seatbelts and a positive IBS cable that damaged when airbags went off... should i do this myself? or is that a good price. im trying to save money here.... i dont think its hard but can someone shed some light... thanks a million
Originally Posted by mikeg3tsguap' post='1017283' date='Sep 25 2009, 09:38 PM
Have you tried googleing or maybe realoem for diagrams?? Btw what bimmer shop u went to?
the shop is called haus of bimmers in the bronx...
i tried but really nothing out there. thought people would know on here..
DavaiLave
08-02-2022 02:16 AM
