Rotor seized onto the hub
Old 04-11-2009, 03:35 PM
BlueHorse's Avatar
My Ride: 2004 525i, Metalic Gray, Premium Package
Why can't I use a mallet to dislodge a stuck rotor? Seems to be rubber mallet will do less damange than a ball pein hammer?
Thanks.
Originally Posted by earossi' post='826103' date='Mar 25 2009, 02:47 AM
...2. Don't use a mallet to break the rotor loose.....you need a 1 or 2 pound ball pein hammer. You need to take a good swing at the rotor on the outside surface.....then spin the rotor 180 degrees and give that side of the rotor a good hit. Then do the same procedure to the inside surface of the rotor. It is surprising just how much force is needed to break some of these rotors loose......but, they will come loose! You should be ready to replace the rotor rather than turn down the rotor since you can damage the rotor hammering it off...
Old 04-11-2009, 03:44 PM
donpb's Avatar
My Ride: '06 530i N52
you'll get more vibration force with the ball pein. that's what really knocks it loose.
Thanks.
Old 04-15-2009, 04:09 PM
earossi's Avatar
Thanks.
Yes, you can use a rubber mallet; however, you probably can not put enough force into a rubber mallet hitting the disks. But, give it a try. You might have to go out a find a 5 pound rubber mallet!
militantgrunt
09-10-2015 02:31 PM
PelicanParts.com
08-13-2015 01:45 PM
rkilpa
08-04-2015 06:14 PM
brente91
07-12-2015 03:12 PM
Quick Reply: Rotor seized onto the hub
