Roof spoiler about to reattach to someone's windshield
I've had this rep roof spoiler installed by a bodyshop using some kind of 3M glue? :thumbsdown: Fitment was good but it stayed on for only 2 weeks and now half of it became unglued!!! Does anyone have this style of spoiler and if they had success securing this down? The available conduct surface is about an inch along the spoiler so it isn't as wide as the ACS style roof spoiler, however it should work, shouldn't it? I really like this spoiler and am looking for a solution.
Thanks guys!
Thanks guys!
My Ride: 2000 540i/6: Silver
Model Year: 2000
hey i have this same spoiler and i have the SAME problem.
The shop put it on with some shitty glue, the right half of it is off, it just vibrates like crazy when driving.
I bought a couple of different kinds of epoxy today, and im gonna try to reapply it.
I will let you know how it holds up. It says it has a 24hr curing period, so I'll know tomorrow night.
Thanks guys!
Attachment 112184
Thanks guys!
Attachment 112184
I woould not use an epoxy because that is overkill. 3m DS tape is perfect. The red one!
Thanks luigi524td, makes a lot of sense.
Hey Anzafin, you guys with the ACS ones are lucky because those have more contact surface for sticking, 3 - 4 inches? and they sit totally flat. Whereas my rep Hamann has 2 inches (max) surface for glue.
Hey FRONJONI, tonymac may have a point. epoxy could really f'up weather-strip if it doesn't work out. Let us know how it goes thou. More importantly, how it holds up in a week after at least 80 speedo on the freeway. Thanks!
Update discovery: Having hands on cleaning the spoiler contact surface made me realize there is grove along it that supposed to go 'directly' over the rear window weahter stripping. So, in retrospect, the shop made the mistake of installing it direclty on the rear glass, about a half inch lower than the weather-strip where placement was incorrect. The groves on the spoiler should be placed directly over the rear window weahter strip! This fitted so much better and could explain where they went wrong. I am 100% confident of placement now, however, I still have low confident about the type of glue used. Whether 3M double-sided tape and silicone RTV (both came with spoiler), the shop's own 3M black glass glue or others...cuz now if I have to pull it off again, it may damage the rear glass weather-srip and that will open up a new can of hoopa$$!!
Still looking for
Still looking for
Model Year: 2000
That 3M double sided tape doesnt work at all. Mine always comes off in under 15 minutes of driving.
The problem is, the spoiler is a rep, fitment is far from perfect. You need something strong to hold it down in the places that it flexes back up.
Epoxy may be overkill, but 3M tape on the weather strip, and epoxy on the glass might be the right solution.
If not epoxy, then a silicone. I didnt get a chance to apply the epoxy this weekend, I think i might just take the whole spoiler off, sand it down, give it some porosity, and do a proper installation.
I used some stuff called Goop from Autozone - stronger than silicone, not as much overkill as epoxy and will not damage paint (it can be removed with Acetone). 3M tape does not hold it alone, I actually used both.
