resetting oil change in idrive
#51
My Ride: 2007 530i
I tried the method described in post #48 and didn't have any luck. I have the remote that fits into the ignition with the start/ stop button.
I also tried the i drive menu. Using the wheel.
after the law screen press down for 6-10 seconds
three clicks clockwise
three clicks counter- clockwise
one click clockwise
one click counter- clockwise
one click clockwise
press down normal
I didn't get anything out of both methods and several tries. I also tried a couple different things like reversing the clockwise counter- clockwise order. Maybe BMW got wise to this and changed the combo?
Has anyone on the board tried this with the new push button ignition, besides myself?
one click clockwise
one click clockwise
press down normal
#52
My Ride: 530i Built Nov 06
Silver Grey with Black Leather
Steptronic Automatic Tranmission
Premium Package
Navigation System
Sirius Satellite
Red Reflectors :-)
This thread is awesome!
I tried the tachometer reset method above and it worked fine for me. Took me a few minutes to reset the oil meter. Just make sure you turn the ignition on; with the start/stop button model, turn ignition on by pressing start/stop button while leaving the brake pedal off (to avoid starting your engine).
#53
My Ride: 2007 530i
#54
Please, anyone can help me? I am trying to reset the "braking pads warning" and when I long press the "reset" option it gave me - 15000 km...so I still get the warning ....
What can I do?
Tx
What can I do?
Tx
#55
I used this procedure to reset the "microfilter due" notification after I replaced the microfilters. The odd thing is that it came up with the new interval of 120,000 km. This seems too long. I think the original interval was about 50,000 km.
Is there anyway to adjust the interval after reset.
The other strange is that I can no longer adjust my idrive brightness. It is now on full brightness. I did get into the test mode while trying to reset the service indicators. Any ideas where I went wrong?
#56
My Ride: 06' 530 Alpine/Auburn/Dark walnut, Sport, Premium, Sirius, 35% Tint
Upcomming mods: M166's/Exclaim UHP's, Mtech
Originally Posted by ledbettm' post='195264' date='Nov 8 2005, 02:56 PM
I also would like to know that too...
This process does not allow you to change/erase fault codes from the car.
#57
Oil change countdown.
This is supposed to happen i understand when you turn the key on momentarily in the dashboard centre with miles/kms to go. Mine is 'fixed' on 8000 regardless of car being driven rather than counting down. Ok i can do basic maths but that is not the point!! Any ideas anybody?? I imagine it was not reset correctly last time by BMW (before i had the car).
Everything else is fine, no faults. Anybody else experienced this or something similar?
#58
Update.
Upon further investigation the display when key turned on is accurately reporting the next due service in terms of mileage and date from idrive service menu.
The problem is ALL of the items in idrive menu report various mileages in whole 1000's eg 8000, 16000 NONE of them are ever moving. How has the machine managed to stop counting down?
Does this mean i never need any servicing
Seriously can anybody help, or is this an upgrade software/reset service indicator type issue at dealer. Dare i suggest the last BMW service techhie may have may a hash of resetting intervals? Btw I didn't own car then, so was not sure initially this was a problem.
Any suggestions please...
#59
Ok people. To avoid myself looking too silly
i think the penny has dropped. The figures went down by 1000 today to next service, so i assume this is working perfectly normally.
Not very well illustrated in the manual, i would add in my defence. I must check more thoroughly before posting. Written out 100 times by tomorrow morning!!
#60
Originally Posted by nicke60gre' post='190405' date='Oct 29 2005, 06:48 AM
Hi kreate2
Welcome aboard
Press the tacho reset button in the instument cluster about 10 seconds with the key to on position, until "service" appears, then change selection with a sigle push
until "engine oil" appears. Keep pushing the "reset " ask yes? and that's all. Next oil change after 25000 Km appears on the idrive "service"menu.
Beware, not to reset another function, there is no way to restore a reseted item.
Regards.
Welcome aboard
Regards.
Do you know what software & Hardware other than a PC l would need to buy to carry out service & Maintenance works on a 06 Model?
