Resetting Engine Trouble Codes
My Ride: 530i
I recently changed out the spark plugs in my 2004 530i. After I finished, I decided to investigate an engine whistling noise that has been plaguing me since I bought the car. A few months back my local dealer changed out the throttlebody assembly and since the noise was still present afterward, referred to the noise as being normal and part of the engine's design. A "venturi effect" was what they described it as. They refused to look at it any further. To sum things up I removed all of the intake cleaner box and pipework up to the throttlebody to inspect it for cracks. With nothing evident I decided to start the engine with these items removed. Sure enough, the whistling sound was coming from the throttlebody. Now that I know there is nothing that can be done I may finally be able to live with the annoying sound.
When I put everything back together and fired up the car I had the check engine light on the instrument cluster and a warning on i-drive stating to see the nearest dealer for service. This fault code was from the disconnected mass air flow sensor earlier. I searched on the internet for a way to reset the code but could not find anything. I was nearly ready to take it to the dealer to get the code cleared when I remembered the 25s fix for a rough shifting transmission. I decided to give it a try. Engine off. Gas pedal held to the floor. Key turned to ignition but not start. Wait 25-30 secs. After I did that and started the car, the check engine/error message was cleared. It seems the 25s fix not only clears the adaptation values but it also clears any engine troublecodes as well. I'm sure the dealer wouldn't be willing to share this information.
My Ride: 2004 530i Grey
I just did mine at 90,000 kms - I also have a 2004 530i.
Do/will you still be taking your car back to the dealer for servicing - I'm trying to find a good independant shop in around Toronto?
My Ride: 530i
Originally Posted by Technik1' post='1005354' date='Sep 11 2009, 11:20 PM
BTW how many kms did you have when you changed the plugs ?
I try to do most of the maintenance myself. If there is a warranty issue I bring it back to Durham BMW in Ajax. I still have the remainder of the CPO warranty left.
Durham BMW seems reasonable with labor charges. They charged me a 1/2 hour to retrofit bluetooth software and 1 hour to retrofit sirius in i-drive. Not too bad.
DavaiLave
08-02-2022 02:16 AM
linxuan
E39 Discussion
03-22-2015 06:16 AM
