replacing side rails
i plan to install m5 lower body side rails to me 07 550 sport. i hope to do the front and rear fender aero kit later. anyone have instructions on how to remove the rails. i see bolts on the bottom and assume there are clips behind but i'm not sure where to start pulling. any advice would be greatly appreciated.
thanks in advance,
jeff
thanks in advance,
jeff
My Ride: G30 M550i
Model Year: 2018
Welcome Jeff!
I did a quick look for specific instructions but couldn't find anything quickly. I'll look some more maybe later when I have a few more minutes. In the meantime, the following diagram may shed some light on how things are attached:
http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=20
My Ride: 2007 530i, build 03/06, European delivery 05/05/06, Mystic Blue Metallic, Beige Dakota leather and Poplar Grain wood trim. Options: Sport Package, Active Steering, Park Distance Control, Premium Package, and Cold Weather Package. Upgrades: BMW Ellipsoid (Styling 121) cast alloy wheels, AC Schnitzer Aerodynamics Kit, 3M Clear Bra, and RaceMesh Grill.
The removal of the side skirts is fairly easy. Just remove the torx-bolt at the ends and remove the securing pins along the bottom of the skirt. Once all the pins and bolts have been removed from the bottom pull from one end of the skirt until the first clip snaps loose and continue pulling on the adjacent clips until the skirt is removed. You may want to have a few extra clips in case some break during the removal procedure. Good luck.
thesalboy
04-08-2015 09:13 AM
