Replacing Front pads and resetting service interval
My Ride: 2005(55) E60 M Sport. Silver Grey, 19" wheels, Media Pack, Visibility Pack. Black Dakota Leather, High Gloss Dark Maple Wood.
Guys,
I did a number of searches on how to replace the front pads and reset the service indicator. Having found all the answers I have now carried this task out and thought I would share my experience.
My pads were getting a bit worn with the iDrive saying I had 1900 miles left. It was a nice day so I thought I would replace them. Using the information from the Gallery/TIS Information on this forum, I replaced the pads. They still had a bit of meat on them and the wear sensor looked ok.
Rebuilt everything and tested brakes, all ok. Went to reset the iDrive and no go! I ended up with a red warning saying replacement overdue. Every time I tried to rest all I got was -9000 miles. I tried everything but it would not reset.
Took left front wheel off again and replaces wear sensor. Boxed it all back up again. Went to reset via iDrive and hey presto! Worked first time.
I suggest that the wear sensor is replaced every time. If anyone wants any more info PM me.
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
Glad you got it all worked out. It feels good knowing that you saved money on your brakes by doing it yourself.
My Ride: E61 sold nice E91 335i Sport Touring now
I've got a similar problem but fitting a new cable has not worked.
I've reset service items before and everytime I try to reset the front brake pads it just tells me -9000 miles.
I bought a new cable from BMW yesterday thinking that would solve it but it still won't reset. Is there a procedure for fitting the cable? I did it with no key in the car then put the key in and tried resetting and it keeps reverting to -9000 miles!
I did not use BMW pads but the recess was there for the sensor to slot into so I doubt its the actual pads.
Another thing is the 'vehicle check service' which was due in may and I cannot reset that either! If I scroll through then selct it by holding the trip button it just shows an orange triangle and won't do anything else.
I'll try doing it all again
EDIT: Just tried it again and after a few attempts the brake pad has reset to 25000. Phew!
Another problem is its showing stat service overdue but I it wont offer a RESET option. Calling it up so the icon appears in red works and then I hold the trip button and all it does it show an orange triangle for a couple of seconds then it goes away??
My Ride: Estoril Blue 440i GC
Model Year: 2017
The Statutory Service is BMW-speak for MOT time - you can reset it in iDrive.
Mike
Mike
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish.
Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
My front brake pads and rotors also need a change ..Just checked with BMW and they want ~ $900 just for the front!
Planning to do this myself by following the TIS.
any tips and tricks from your experience doing this? How long did it take and did you need to get the special tools?
thanks in advance.
~ V
thanks in advance.
~ V
thanks in advance.
~ V
thanks in advance.
~ V
thanks in advance.
~ V
thanks in advance.
~ V
Lastly, change the sensor and use a brake pad that you feel comfortable with. Meaning, if you like the OEM performance, go with a pad close to OEM performance such as Textar Centric, which is what I used. Some people use Axxis and various other aftermarket brands in attempt to mitigate brake dust, but come to find the performance is lacking in comparison to an OEM pad.
Originally Posted by anand_rahim' post='936089' date='Jul 8 2009, 07:13 AM
First and foremost, make sure you have proper hydraulic jacks and jack stands. The last thing you need is a trip to the hospital. Next, make sure to get a torque wrench, this will ensure every bolt is tightened to BMW specs.
thanks a lot. did you need to buy the special tools in the TIS and did you bleed the brakes after the change? I have done pad/rotor changes in other cars like honda but I am not sure if the E60 has the same mechanism.
