Removing the trunk lid liner
I am getting "License plate left lamp malfunction" messages when I start the car, so I guess I need to change the bulb.
The truck lid liner appears to be attached with snaps, but before I go and break something, I figured I'd ask if anyone has ever removed it before. Is it a simple getting a screwdriver behind it to pop it out of it's hole or is there something else I should be aware of before I attempt this? Also, if you happen to know the specs on the bulb or part #, I'd appreciate that also. |
go to bmwusa.com and look for the car's owner's manual. It will have instructions on how to change the light bulb.
Done! Thanks to all!
