Remove wheel spacers
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Okay,
I was excited with the installation of my 10mm H&R wheel spacers back in August 2006. Now that I have 12mm spacers available and a lot of time these days, I've decided to replace the 10mm with 12mm. I've done the search on how to remove and found this little tidbit:
There's more but I'm not going to keep quoting them. You can find the thread here: http://forums.e60.net/index.php?s=&sho...st&p=147943. I highly doubt that the guy that installed my springs and spacers lubed the spacers with anti-seize compound. If I can't find a way to remove the spacers, it looks like I'll have to destroy the 10mm. Can anyone help me out? Thanks.
I would recommend that anyone that just installed spacers removed them and lube with anti-seize before putting them back on.
I agree If you mix different types of metals like alloy to steel than you will get the metal frozen to one another. Anti-seize solution may work also. It happened to me once and not even a air-rachet could remove the bolts. I would use some kind of lube and check it often. FYI
Scowering all the BMW forums for an answer. Someone mentioned a blowtorch to expand the aluminum.
My Ride: 2007 550i, jet black/black dakota, sport package, steptronic, L7, comfort access, rear sunshade, front heated seats, navigation, satellite radio
also have
2006 Dodge Sprinter
Been spraying on Liquid Wrench Penetrating Oil. Nadda. :'(
Wouldn't the steel chisel damage the aluminum spacer? Well, I'm going to give it a shot anyway. I was going to sell the 10mm, but if it gets damage so be it. I still have my 12mm.
Model Year: 2015
Engine: N55
I had the same problem trying to get my wheels of, the Ally wheels were welded to the steel hub.
I had to hit two of the tyres repeatedly with a sledge hammer to break the 'weld'.
Now I make sure a put some 'copaslip' on the hubs every time the wheels come off.
No help to yuo I know, but good luck Vegas.
Thanks for the heads-up Vegas would you know which Anti-Seize product specifically we should use?http://www.antiseize.com/
Originally Posted by vegastrashed' post='382433' date='Jan 23 2007, 04:42 PM
Okay,
There's overall a lot of doubts of the spacers.
First, they kill the factory settings by wider the axel radious.
Second, they for sure will set the bearings etc. for a bigger force than planned.
Third, are they really good for the driving emotion?
And now this...
And now this...
My Ride: E60 530dA 3/2004
And now this...
And now this...
Mine also, I noticed was those stupid plates. i asked the sale guy:"what are those?, They are spacers. Aha, I said, What are those good for?, they make 275/35/18 to look even more better, Aha, I said and what they do for bearings?, Hmm, was the answer. I said: Can You remove those immidiatelly?, Yes, we can"!
Don't know how tight they have been, anyway after 20 min the car was in normal condition.
