rear door panel help!
My Ride: Bmw 530d 2004
Why don't you people ever search? This has been posted numerous times on the forum.
http://tis.spaghetticoder.org/s/view.pl?1/08/93/84
- Antti -
- Antti -
Ive seen it before but it not enough... I unscrewed the 2 phillips head screws and popped the plastic clips of.. but it doesnt come of.. do i need to remove the window switch cover? I dont want to break anything... Some pls help
It still stays attached on the upper edge, right?
Start pulling the top edge off on the rear end and it will pop right off (picture #3 in a TIS document). You may have to use some force, though. You don't have to touch the window switch cover.
- Antti -
- Antti -
sydmaz
05-16-2015 10:21 AM
