Radiator Host replacement
My Ride: 04 525i, 04 Dinan M3
Anyone ever replace the radiator hoses before? My hose has been leaking and now the leak is very bad. I have to replace the host before I can drive the car. I have the host and sensor but its so hard to get to. Its the radiator return hose on the left
have you checked the diagrams from realoem.com?
http://www.realoem.com/bmw/diagrams/m/j/185.png
IIRC, your e60 is a 525i (sorry it's not listed in your sig and you debadged your ride)
Got the old hoses off. I can't get the new ones on, they have the clip you pull back and it should go right on. Does anyone know if there is anything special I need to do?? Help
My Ride: 2004 BMW 545i
I need to replace the same hose on the passenger side for my 2004 545i with about 60k miles.
1) Is there a drain plug and where to lower the coolant level in the radiator?
2) How did you remove the old hose and install the new one?
Help is appreciated.
tnixa
05-21-2015 11:01 PM
