radar det
Old 04-19-2012, 12:20 PM
  #271
545iBMW's Avatar
I know this is an old thread but I'd never be able to install my Redline if not for this thread.
Thank you Don Juan.
Originally Posted by Don Juan
Well here are the pictures of the V1 looks from the outside (the camera flash makes the tint look lighter than really is)
Old 06-03-2012, 03:36 PM
  #272
jcantanixon's Avatar
Thank you Don Juan.
Same here. Very helpful.
Old 08-24-2012, 09:56 AM
  #273
don6241's Avatar
Im trying to hardwire my escort 9500i to my 2008 535i. I have gone through all the wires and the green/yellow wire is not working. I even stripped some of it and put the wire directly on it to see if it would work and it didnt. The only wire that works is the red wire but the radar stays on even when the car is off. I attached a picture of the green/yellow wire that I used and did not work. please if anyone can think of why its not working let me know. thanks.
Old 08-25-2012, 03:26 PM
  #274
jamie75's Avatar
you are tapping the wrong green yellow wire, you need to get the one out of the bundle right behind the one you are working with in your picture
Old 01-26-2013, 01:34 PM
  #275
Tooch01's Avatar
Just followed Don Juan's step by step guide and have my passport 9500 direct wired and mounted via blend mount bracket. Thanks!!
Old 02-19-2013, 06:40 PM
  #276
Mikey B-mer's Avatar
My Ride: 2008 Metallic Green 535i,Dakota Brown leather,NAV,HD Radio, Comfort Access,Sport pkg,Premium Pkg,Cold Weather pkg,Logic7,Park Distance, SAT/Paddles, Ipod adapter, tint, LED Side markers, & halos, heated fronts,CPO'd car, tinted tails, heads, reflectors, backup camera, afe cold air intake, led license plate lights, rear lip spoiler, recoded modules: remote folding of mirrors, deleted accept screen on idrive, auto unlocking of door when ignition turned off, closing windows, & sunroof w/ remote, digital speedo on instrument cluster.
Thank you Don Juan! Just wired up my 2008 535, & works like a champ! Thanks to all who contributed also
Old 03-10-2013, 04:49 PM
  #277
jdmek998's Avatar
Thanks for the write up. I just installed my passport 9500. but I hid the mute button inside the SOS button came out perfect. Thanks for the write up!
Attached Thumbnails radar det-img_3441.jpg   radar det-img_3442.jpg   radar det-img_3443.jpg   radar det-img_3444.jpg
Old 08-09-2013, 08:49 PM
  #278
i545i's Avatar
My Ride: 545i
bringing back the thread, I can't find the green/yellow wire on my 2004: 545i / Any other power source?
Old 11-16-2013, 06:03 AM
  #279
sfcacique's Avatar
My Ride: 2001 M5, 2010 e61 / 535iXT Automatic
Model Year: 2001, 2010
Okay, I tried to install this for over an hour last night, in a rather dimly lit garage. I was over confidant since I have installed this remote V1 system previously in my 1998 740iL, my 2001 M5, and 2006 530iXT. Those cars have gone on to other owners (minus the M5), and I have a post LCI, 2010 535iXT.
I was really surprised when I popped off the square ceiling cover, the green with yellow wire was right there, up front, easy to say and manipulate. I immediately tapped into it, looked for a ground and was disappointed that it did not work. I ran a set of jumper cables to a ground under the hood (I like to restrict the factors of concern), still no joy. I put the mutimeter probe into the blue connector and got intermittent readings. I removed the plastic cover exposing the metal prongs and tweaked the connections to insure I had a good connection. Hooray, it worked...as far as power went. Now when ever I turned on the V1, the moonroof would open/close. So.... never experienced that before.
I went inside, had a couple of chilled vodkas, thought about it and slept on it.
This morning I went out with better lighting and found a green with yellow wire (the yellow is so faint, it actually looks like a glare/shine on the green wire) in the OTHER wiring bundle. HINT: look for the wiring bundle that has the dashes on some of the wires, along with single and multi-lined ones. Basically, it is almost like looking for a green wire that "might" have a yellow line.
Redid the connector, (I used a pair of needle nose pliers with the blue connector open and the wire placed in correct splice position, then squeeze until I see good contact through the plastic coating. Checked out operation, good switched on/off and no apparent conflict.
(BTW - invest in some real interior/upholstery tools. The tools make the job a LOT easier, and less stressing. A side benefit is protecting those little pressure connectors. My M5 has been with me for a decade plus, so I have gone into that cluster many times.
Old 11-16-2013, 06:11 AM
  #280
sfcacique's Avatar
As a follow up, although I previously had the Jaric Designs Stealth One (V1S1) in the M5 and 740iL, the current BUS system in the 2010 is not supported by S1. SO... Valentine has something interesting ANDROID-V1connection, the V1 Connection allows the V1 signal (and MORE) to show up on your paired android or iPhone smart phones.
Since I just emplaced the remote power, it is real easy to install the V1 connection to the AUX RJ11 connector, and emplave in the same location along with your remote power for V1. I'm going to try it with YAVA (Yet Another Valentine App) vice the Valentine App. App Reviews show YAVA and being more stable, and having better features, including the option to turn off alarms under a certain limit. Good for guys like me that live in small neighborhoods with a very predominant police force and basically cannot EVER speed without a 50/50 chance of being hit by radar. So everyone drives 25mph..
Quick Reply: radar det
