Pre-LCI to LCI Lights - What to look out for during the install
#25
My Ride: 520d M Sport
Titanium Silver
Retro fit's -
Professional Sat Nav
Footwell Lights
BMW Bluetooth
LCI Halogens with HID
Thank you for this thread it helped alot with my LM2 install today
#26
My Ride: 2007 Black Sapphire 535i
I still believe this was one of the most profound mods I did to my car.
#27
Great post to Pre-LCI to LCI Headlight - i need to help ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
My car is BMW E60 12/2003 whit Bi-Xenon
I already bought LCI Adaptive Bi-Xenons , Control Unit Xenon Light "ballast" , Lamp Holders "ring clips" , Xenon Bulbs D1S w/ Ignition Element , LCI retrofit cable set .
I don't have Electronics box ALC and LM2.
My rear lights are now LCI whit Bruce Miranda V6 cables.
I Have CIC Retrofit - in which I have daytime running lights - work.
?y questions are:
- Can I connect via cable headlights without cutting jacks using LCI retrofit cable set and return to the old jack connectors.
![Pre-LCI to LCI Lights - What to look out for during the install-untitled.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/128102d1482364199t-pre-lci-lci-lights-what-look-out-during-install-untitled.jpg)
as this cable ?..
What do I need to order to make them if I have LCI retrofit cable set?how to connect?
- I will work my headlights if not installed Electronics box ALC and LM2 (I do not keep the adaptive lights and features offered by LM2 - just like the normal operation of the headlights).
- If you must use it LM2 can you benefit from another car after 2007. If you can identify it PN at seen?
- Should I update software of the car (I prefer not to do - I remap the ECU)
Do you know whether this is possible?
Many Thanks
?y questions are:
as this cable ?..
Many Thanks
#29
My Ride: Many BMW's
?y questions are:
Attachment 128102
as this cable ?..
Many Thanks
?y questions are:
Attachment 128102
as this cable ?..
Many Thanks
who's doing this cable ?
