Performing a Nav Retrofit
My Ride: 05 545/6
Originally Posted by Sanj' post='732266' date='Nov 26 2008, 06:15 PM
Hiya everyone,been looking at a few satnav's on ebay(even one's which were advertised by Dr Dave!)and have a few question's,are they easy to fit or would a retrofit loom be required?I have a standard cd player with no nav at the moment,am I correct in saying that it will be easy to fit with just a minimal amount of programming as I went to a BMW specialist and they said that it required upto 30+ module's to be re-programmed to accept the High i-drive controller and the complete Satnav system,no one on ebay seem's to mention this or is this untrue?Dr Dave have you any more unit's for sale mate?
Regard's,
Sanj.
Regard's,
Sanj.
yes mate, i have 2 compleate sets still for sale.
to confirm again, this is a VERY easy retro fit, if you dont know what your doing it will take you about 4 hours in total, if you do its about 2 hours, its all plug and play, the only drama is fitting the new high i drive controller, you do not need to change your sharks fin ariel (just use a small GPS one)
i have done 3 cars now, and 2 did not need any programing at all.
the 3rd one (mine
) needed programing as the car would not recognise the PDC on the new 8.8 widescreen but it only cost ?125
this retro fit is a walk in the park.
the 3rd one (mine
the 3rd one (mine
the 3rd one (mine
My Ride: E60 530d 218ps
the 3rd one (mine
the 3rd one (mine
How much do you want for the prof nav units?
cheers
new loom???? rubbish the connectors on the back of your single disc cd are the same as on the back of the dvd/cd on the pro nav CCC unit, its all plug and play even if you have a basic spec car with no multi changer etc
there could be a half hour of programing cost is around ?125 but you might be lucky, if your car does not have PDC then you can get away with it.
the extra wires are
fan wiring harness and voice harness/microphone
plus a GPRS ariel
this retro fit is easier than changing your brake pads.
dont beleive the bull you hear from people that have not done it, i have personally fitted 3, and there all perfect. (1 to my own car)
you can even re use your LVDS cable.
the extra wires are
plus a GPRS ariel
the extra wires are
plus a GPRS ariel
the extra wires are
plus a GPRS ariel
My Ride: 05 545/6
you do not need to replace any wiring harnesses; however, you do need to add a few connections to the existing harness if you don't already have business nav. there's three wires to be added for the CCC's fan, and if your car is built before 10/2004 you need to run a speed sense wire to the CAS module under the steering wheel. it will work without that speed sense, but your motion will be a bit blocky. You also will not have any motion when the car first moves as it won't have a GPS lock yet. I didn't connect mine at first, thinking I didn't need it, but I noticed the icon wouldn't move for the first 90-120 seconds after I got in the car. I ran the missing wire and now the icon moves immediately.
hi felix, the cars must have different wiring because i did 2 cars that were pre 2004 and they were cloth spec with no nav at all, and i did not need a speed sence cable, and yes i have re used every LVDS cable they are exactly the same on all cars here in uk.
in the uk you need to add voice harness cable and mic, and wire up the fan wiring harness, plus fit an aftermarket GPRS ariel
but its easy peasy, i think a novice could fit this retrofit pro nav, it was the i-drive controller that was a right royal pain in the ar*e
but i have it off to a pat now.
![Cool](https://5series.net/forums/images/smilies/cool.gif)
