Need help with wiring from basic half electric seats to full electric memory seats
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys i needed help with wiring half electric seats to full electric memory sport seats
the car is a 2005 e60
im not sure good to wiring diagrams was wondering if any one could help who has done this mod and has experience with the wiring diagram
i want a easy diy guide that every one could use to do this mod in the future
any one know what wires i need to add to the seats and were they are located and colours
to make the fully electric memory seats
thanks
thanks
got a bit of a idea by checking the wires as far as i can understand are these correct
on drivers seat
i need to connect the Red/Green to Power on rear fuse holder
Brown big wire to Earth
connect K can- SL Yellow wire pin 5 from Seat to Pin 12 on Centre Switch Console
connect K can- hL Black wire pin 6 from Seat to Pin 11 on Centre Switch Console
connect K Bus pin 3 from Centre Switch Console to driver seat adjusment switch
on WDS says to connect to driver seat adjustment switch is this wire not in the yellow connector,
Does this connect to the same black k can Sh wire???
are there any other wires i need to connect?
thanks
on drivers seat
thanks
Done now
just as written above those wires and pins made it work
My Ride: e60 2008
on my seat Can H/L comes from the seat computer with a red and brown wire on a black connector
on my seat controller there is 3 wires (pin 2 red/green) -(pin 3 brown/black) -(pin 23 black) wires, all located on the yellow connector
i tried wiring Can H/L to th H/L can wires from the centre switch then tried to find the Kbus
i tried to power the centre switch and the seat and apply power to the red/green wire and still nothing...
Siim Orasmae
04-07-2020 08:13 AM
Coronita
04-28-2018 01:04 AM
