NCSExpert Code Mods
#81
Blood:
have you please tested ASP_MEMORY? What's the default value?
If nicht_aktiv, then it's not related to key fob profile mirror memory (all models come from the factory with default on - as that's the purpose of profiles) . I suspect that it may be the curb folding mirror memory.
#82
My Ride: 2007 E60 535d M Sport
Ongoing Projects:
M view on HUD.
Reported to work on >2006 models and older models with an M5 cluster.
CAPPL
MDrive
activ
HUD_M
activ
HUD
M_SPORT_HUD
activ
Result: Partial success. Mview shows up in HUD idrive setting and stays ticked (when CAPPL elements above are activ as well) ? MHUD stays on for 30secs and reverts back to normal.
When CAPPL elements are nicht_activ, Mview in HUD idrive setting (which is ticked) disappears but MHUD still shows (for 30sec). Ongoing research.
M view on HUD.
CAPPL
MDrive
activ
HUD_M
activ
HUD
M_SPORT_HUD
activ
Managed to get this working!
And the best thing... it stays on permanently
My car is a 12/2006 build for information...
#83
Congrats!
How did you take a picture of it? My camera doesn't capture the HUD at all. Also it seems the HUD is dynamically mapped. On your diesel with 5000 RPM redline, your redzone is much bigger (twice as big) than mine on my 540i with 7000 RPM redline.
So afterall the M-HUD reacts and adjusts itself to a particular engine, but I found that watching it doesn't seem to be as useful as I thought for some reason (doesn't seem accurate).
Still, the gear display is really worth it! I hated the cluster display which is completely out of driving sight.
#84
I just used my iphone, seemed to work fine ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
You're right about the rev range, the red line is literally where that little yellow part is between the green and red bands - not the most handy thing in the world
Though the gear display is what I wanted most - however it only shows the numbers when in manual mode. In Drive, Sport and Park it's just blank, but in Neutral and Reverse you get an "N" or "R".
#85
Model Year: 2005
Engine: 545i
Good stuff !
As BenAnd has indicated to me my car needs probably an updated CAS module to get the MHUD working (for more than 30sec)
Will look into that at some point.
I have to say I like both the rpm range and gear indication - granted on my car the green zone is obviously longer.
How do you switch back to normal view - like if you have nav on ? Do you switch back via the HUD menu (uncheck Mview) ?
#86
Good stuff !
#87
I'm gettin' the hang of the NCS-Expert stuff ...
In the mean time I thought I make similar archive sharing like the folks @ e90post using ...
Not sure if one already setup or not ...
https://spreadsheets...=CNPs2ucN#gid=0
--Rival.
--Rival.
Do you have a link to the E90post one so I can compare? Thanks.
#88
#90
Please help me, I did the BC_DIGITAL_V and instrument cluster went crazy. It no longer read the tachometer, no longer indicate the tank level, and no consumption. All this happened after I did a software update from BMW dealer. Before the update I've done this and had no problems.Now when i make diagnose with INPA, it say that the kombi has bad data coding. You got a idea?
