NCSExpert Code Mods
#711
My Ride: E60 520I SE
nope - 2.2 petrol
Was talking to my local steelers and according to them there's no new sensor as this one is being installed in newest cars as well. Anyway will have to change oil sensor as this one is giving me "oil level low" and "oil pressure low" errors many times
and I'm checking oil frequently and it's always ok. Will do this when changing oil it two weeks time
You need to replace the oil sensor too from a newer model, idk the part number.. This is a feature enabled by default on newer e60s
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
#712
hai guys,
can any body help me with coding setting.
i have build lci navi prof with 8 radio butons in my car, the favorit button are not working.
0031626517430 i have whatsapp a help will be great.
and i have build mulf2 hih svs with usb aux, my bluetooth function is nit more working, car is from 2004.
i read that i need ssd file to read it in ncs and coded with icom B i have icom,
could anyone please help me iam confused ;-(
#714
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
can some 1 try and help me with a guide or instructions for ncs expert to get the accustic sound when looking my door and unlooking it plese help
#716
My Ride: bmw e60 535d
I have hard times on finding how to make welcome lights working on my BMW because it is using LM1 and i can't find KGM module or CAPPL module or HUD to recode.Can someone help me with this one how to make welcome lights and where to recode?
#717
No need to code other ECUs
#719
LMA: HEIMLEUCHTEN_FUNKSCHL >> aktiv
For Welcome on LM1 try this without quotes:
"https://youtu.be/q5CAUqHIPWs"
#720
My Ride: 2008 535xi
Engine: n54
Does anyone know the specific coding and module that might affect the tilt steering wheel? I did a few things a while back and thought I simply didn't connect something, or a fuse blew. Last weekend I went back under the dash and didn't see a thing. I also tested every single fuse in the car including the glove box and no dice.
I have an LCI and I did a sport mode mod, but I did not have to go into the dashboard where people said there is a plug by the heated seat/radio console, so I am ruling out having a plug there.
The last thing that I did was code out the steering wheel tightness when on sport mode:
GESCHWIN_WERTE_SPORT_KGM
STROMWERTE_SPORT_KGM
I haven't had a chance to take a closer look to see if my tilt steering motor is jammed or not getting power yet.. it has to get a bit warmer for me to do that again.
