NCSExpert Code Mods
Old 11-15-2011, 05:37 PM
  #491
black360's Avatar
My Ride: 2006 525i
i coded my DRL to show up as an option on Idrive but when i click it off the DRL's don't go off ..any help would be much appreciated
Old 11-15-2011, 06:03 PM
  #492
BlaSTiWi's Avatar
Try to be more specific on the info like what is the build date+year of the car ... likely due to you have older LM.
Coded something to show doesn't give anything if the limitation is due to the suitable function is not actually available.
Old 11-15-2011, 06:23 PM
  #493
black360's Avatar
My Ride: 2006 525i
2006 525i, i just figured that the DRL option wouldn't be a problem , but i guess so
Old 11-15-2011, 06:55 PM
  #494
EUAutoHaus's Avatar
hey buddy what type of car do you have? Assuming that you coded CAPPL for the feature doesn't mean that you have actually done anything besides made it display in your iDrive menu. Do you have a newer LM? The DRL is a feature that you can use NCS or Progman to manipulate I don't think you'll have the ability in iDrive to enable it or disable it on demand. You may have the option but that doesn't mean it will actually work.
Old 11-15-2011, 07:10 PM
  #495
BlaSTiWi's Avatar
You have LM1 and selectable DRL (similar like Welcome Lights) option available w/ LM2 for car probably around Sept. '06 build (not model year) and up.
Old 11-16-2011, 04:15 AM
  #496
black360's Avatar
My Ride: 2006 525i
ohhh alright thanks guys, if i don't have the ability on idrive could i manually encode it to off using NCS?
Old 11-16-2011, 04:44 AM
  #497
BlaSTiWi's Avatar
The DRL? You can try, try to attach your LM .trc file ... it should be there somewhere.
Old 11-16-2011, 05:06 AM
  #498
black360's Avatar
My Ride: 2006 525i
alright I'm a double check later on thanks, also another quick question .."DRL_wert_dumming" and its set at wert_01 ... is this how bright the DRL is ? and if i would to out it at a different value like wert_04 would that make any difference? thanks again for you help bro
Old 11-16-2011, 05:24 AM
  #499
BlaSTiWi's Avatar
I think on that function if you bump up the wert_ number it'll get brighter but I'm not so sure as my car came w/ LM2.
Old 11-16-2011, 07:07 AM
  #500
black360's Avatar
My Ride: 2006 525i
alright I'm a try wert_04 , but thanks a lot man appreciate the help
Quick Reply: NCSExpert Code Mods
