NCSExpert Code Mods
Old 10-06-2011, 11:41 AM
  #461
Ehssan's Avatar
My Ride: Many BMW's
Originally Posted by BLooD
need to set these as well :-
C941C_QUITT_AKUST_KLAPPE: fkt_frei
K9416_QUITT_AKUST_ENTSCH: fkt_frei
C9413_QUITT_AKUST_SCHAERF: fkt_frei
then set the functions in door locks menu.
Well , not sure if it has any affects ,, I'm looking at my CAPPL trc file , and the 3 codes you've mentioned above has different values , but as soon as I activated the Acoustic in CAPPL , set the function under door lock menu ,, everything worked just well ..
fkt_gesperrt
fkt_gesperrt
fkt_gesperrt
Old 10-07-2011, 05:01 AM
  #462
markie's Avatar
Sorted.
Thanks for the help again Blood/Ehssan, car now makes a nice chirp on lock/unlock.
Does anyone know where this setting is held? - I'm trying to keep a 'backup' of my cars settings so if I ever piss about with it too much I can revert back to my old configuration.
Old 10-07-2011, 11:26 AM
  #463
bruce_miranda's Avatar
Getting back to original configuration is just a matter of recoding the ECU using the Expert profile.
Old 10-08-2011, 06:06 AM
  #464
Georgieb's Avatar
My Ride: 2007 Black Sapphire 535i
I did exactly the same for my car ,, just in CIC , Activated the ACOUSTIC and it works without changing anthing else ..
Ehssan,
Do you remember if the line of code in the CIC is the same as the CCAPL?
Alarm sound - ACOUSTIC
aktiv
I haven't pulled out NCSExpert in a while but I think this is something I would want to activate also. Having audible confirmation that the car is armed, definitely works to your advantage.
Old 10-08-2011, 10:26 AM
  #465
Ehssan's Avatar
My Ride: Many BMW's
Originally Posted by Georgieb
Ehssan,
aktiv
in CIC it called
ACOUSTICAL_LOCK_CONFIRM
aktiv
Old 10-10-2011, 12:59 PM
  #466
Georgieb's Avatar
Ehssan,
Thanks for making life easy. Took me five minutes to update and works like a charm!
Old 10-17-2011, 02:33 AM
  #467
fov001's Avatar
My Ride: 525i M54 2005 Alpine White Sport/Cold/Premiun Sound/Active Steering Navigation/PDC/sport seats/6 CD Changer
hey guys, can someone confirm if this method will work with my 525i 2005? This are instructions on how to disable the Legal Disclaimer that pops up when the car is started, using NCSExpert....
http://ausbmw.com/tutorials/NCSTutorial/
let me know if this will work.
Thanks in advance!
Old 10-18-2011, 05:43 AM
  #468
C_o_s_m_i_n's Avatar
Could anyone tell why do i have this error when reading some of my car modules with NCSexpert? I.e. LMA or KBM.
When i read and code CAPPL, IHKA, PDC or KOMBI, no errors.
The car is E60 520d 08.2008.
Old 10-18-2011, 07:38 AM
  #469
BlaSTiWi's Avatar
It's pretty generic error not much to tell ... But that error window clearly state to take a look at your log files ... Chk them first and post pics of both of them.
Old 10-18-2011, 07:52 AM
  #470
I only found error.log in C:NCSEXPER/BIN.
ERROR! Modul: COAPI.CPP, Proc: coapiGetAbsPathInfo, LineNr: 01, ErrorNr: 1000
COAPI-1000: error
Quick Reply: NCSExpert Code Mods
