NCSExpert Code Mods
#341
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
#343
My Ride: Many BMW's
in RLS module
FLC_SCHWELLWERT_SATZ
wert_01]
wert_04] = sensitive
wert_02 = normal
wert_03 = very sensitive
1+4 = sensitive , when you change it to 2 it will be less sensitive but still acting strange for some reason ,, I found it in my M5 acting according to the speed , I have a tunnel which I ( used to ) pass through everyday going to work ,, if I drive slowly ( because of some stupid driving slowly ) the lights comes on in the middle of the tunnel , if I drive fast , the lights comes in as soon as I enter the tunnel ..
Madein , you are lucky , I found those in my netbook , very strange as I didn't ready did much of coding on my netbook , all the stuff are on my laptop back home ..
anyways hope it helps you ..
LM2 trc original.txt
NETTODAT .txt
wert_01]
wert_02 = normal
NETTODAT .txt
#345
So should I have changed it from:
wert_01
wert_04
to:
wert_01
wert_02
...When I coded it yesterday, I actually changed it to:
wert_02
wert_01
wert_04
to:
wert_01
wert_02
wert_02
#346
Model Year: 2011
in RLS module
wert_01]
wert_02 = normal
Attachment 121513
Attachment 121514
wert_01]
wert_02 = normal
Attachment 121513
Attachment 121514
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
thanks a lot
#347
Model Year: 2011
This is correct, only value wert_02, the rest just need to be deleted
Now, if you can't see any changes in the sensor behaviour, try from beginning.
Sunny day, car in the shadow reverse the changes back to:
wert_01
wert_04
read it back to confirm and you will see, if the lights are coming ON, than change to:
wert_02
and I'm sure, it will stay OFF, if it doesn't work, you have try progman
#349
Model Year: 2011
#350
Are you coding CAS>RLS or LMA>RLS?
The only reason I ask is because I have done previous coding to bulb checks under CAS>LMA and this also didn't work. (I have been successful with the digital speedo, so coding is working)
