NCSExpert Code Mods
#271
Model Year: 2010
As I understand it, if a parameter is not shown in the trace output for the ECU (eg LMA), that parameter is not supported by the ECU. I think your LMA module does not support welcome light coding.
#272
Model Year: 2010
For module MSHD:
REGENSCHLIESSEN
activ
REGENSCHLIESSENTILT
activ
I got the sunroof rain-close to work. I tested by turning ignition on (no need to start engine), turned on auto wipers, used sprayed some water on the windshield glass in front of the rain sensor / rearview mirror. Sunroof closed by itself. It may take a second auto wipe to activate sunroof rain-close.
This next part I don't have an answer for yet: After rain-close, the sunroof switch is in operative. The sunroof stayed closed. I even tried cleaning and drying the glass in front of the rain sensor, turned engine on/off/on, locked/unlocked/locked vehicle. No go. I wonder if it takes X seconds / minutes before the sunroof can be operated again after a rain-close.
REGENSCHLIESSEN
activ
REGENSCHLIESSENTILT
activ
#273
My Ride: BMW E60
Model Year: 2016
You can retrofit LM2 if you'd like, but it's a $300-$400 part.
#274
Double flash hazards guys, i figured it out.Read the lma with NCS and open NETTODAT.TRCB 00340500,0010,95,71,00,83,0A,00,51,00,14,53,01,15, 59,04,00,00Yours will have 95 change it to 97 and save it as NETTODAT.MAN, select basic functions/coapiCodeSgByNettoDATAType "NETTODAT.MAN" in the requester box, select ok and your done.
http://www.youtube.com/watch?v=AYaE09K6JoQ
#276
#278
hey Mr M,
very slick manoeuvre buddy, ya neva seize to amaze me lol
#279
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
Hi Blood it is amazing
just did it on mine - only differences is I have LMA 1 and the sentence: "B 00340500,0010,95,71,00,83,0A,00,51,00,14,53,01,15, 59,04,00,00" was slightly different, just changed the value of 95 to 97 and it is working perfectly.
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
Did you compare the FSW files after coding?
The only differences I can see is than the:
BLINKIMPULS_WARNBLK wert_01
disappeared from the new FSW trace file.
In this case just maybe delete this from the FSW and code it as usually do the job?
This may do the job for the rain sensor sensitivity as well on the Idrive menu?
Even maybe welcome lights for LMA1 owners?
Definitely looks like you opened a "PANDORA BOX" for all of us E60/61 owners.
#280
Model Year: 2011
