NCSExpert Code Mods
Old 04-18-2011, 12:44 PM
  #231
BLooD's Avatar
Originally Posted by jay77
Interesting Whats Traffic+ give?
A shame if it only works with certain phones though
Dont know yet, my phone needs a tether, waiting for orange to sort it out. Will not realise info untill it works as requires certain hardware revisions and software to work.
Old 04-18-2011, 11:24 PM
  #232
r9ndy's Avatar
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
i tried changing the ringtone it doesn't seem to show up under the TCUM module for me
Old 04-19-2011, 03:58 PM
  #233
r9ndy's Avatar
tested the following today
adds light sensitivity to idrive menu
cappl
rain_light_sensor
aktiv
C750A_SCHWELLWERT_EMPFIN
par_gesperrt -> par_frei
C750A_SCHWELLWERT_NORMAL
C750A_SCHWELLWERT_SEHR_E
i got these values from e90post.. i was able to add the light sensitivity to the idrive, however, when i try to change my current setting, sensitive, to slower it changes for a second and then it goes right back to the original setting. any ideas?
rain sensor sunroof/tilt closes when it rains
MSHD
REGENSCHLIESSEN
aktiv
REGENSCHLIESSENTILT
aktiv
this option worked for me.
I also coded the following
Bright AEs at all times - The orions looks much better at night.
Cornering light - will test this out tonight
windows up with fob - works like a charm
added Welcome light/Cornering light/Daytime running light in idrive.
unlock all doors when ignition is turned off
As for clearing codes I need to have my driver restraint error cleared and the passenger side error bag cleared. I tried to clear this via INPA>error>read EM>clear EM. it says everything is cleared, but when i run the read EM the same errors remain. Is there a different way to clear this?
Next coding project CIC nav and combox..
Old 04-20-2011, 05:31 PM
  #234
NoQuarter's Avatar
Engine: N54
Nice results R9ndy - thanks for posting the results.
Good to see the sunroof/rain sensor works for you. I have tried it on 2 different E60s with no luck... apparantly I did the same thing wrong twice.
Did you have to do anything to "make" it work? I wonder what was different between you doing it and what I tried ???
Old 04-20-2011, 05:40 PM
  #235
r9ndy's Avatar
no idea. i just changed the values to aktiv
Old 04-20-2011, 10:07 PM
  #236
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
Originally Posted by BLooD
Teleservices and traffic info+ sorted. Only thing now is it`s complaining about my mobile phone.
Blood it is really good job , just wondering, how you managed to have the signal bars for the phone? On my one is only the "antenna" symbol without those bars .
Old 04-20-2011, 11:21 PM
  #237
BLooD's Avatar
R9ndy? the rain/light sensor settings are tied to the car/key memory so you wont be able to change them im afraid, the setting can be changed via the retrofit menu in progman.
Madien?, it should have the signal bars, thats a standard feature.
Old 04-21-2011, 12:49 AM
  #238
bruce_miranda's Avatar
Thats a feature of the phone rather than the car. Some phones show this, some don't.
Old 04-21-2011, 02:05 AM
  #239
d4rkchocolate's Avatar
Really? i wish i could get this to work on my MULF module... when i had my TCU Module installed before i reverted back to the MULF, it had the bars, it even rang differently through the car. i wish i kept it now.
Old 04-21-2011, 02:23 AM
  #240
mmitev's Avatar
In relation to this: I also see only the antenna and no bars.
However, once I saw a small mobile phone icon, probably between the "TMC" lettes and the antenna on the iDrive display - anyone knows what it is?
Quick Reply: NCSExpert Code Mods
