NCSExpert Code Mods
Yes i read it. I already did my BC_DIGITAL_V, VIDEO_DENY_C0B but for WELCOME LIGHT i did VA_WELCOMELIGHT and it appears in iDrive menu, but i can't activate it, i can select it, but in 1 second it is unselecting it self. In my FRM module i don't have anything about WELCOME LIGHT.
The strange thing is that when i read the hole car i find WELCOME_LIGHT nicht_aktiv, but i can't find it in individuals module to make it aktiv. Any ideas?
Please help. The car is e90 from 10.2006 and it has xonon lights with adaptive light, navigation (proffesional for EUROPE)and iDrive .
On the E90 is the FRM the Light module? If so and you dont have the options your module needs to either be updated or you need a newer one. You can not get the option to work without coding the Light module as well.
On my E60 I do not have the option in my Light module so although I can enable it in idrive the car doesnt know what to do with the instruction, so unselects the option in idrive..from what you describe you can not enable the option unless you update the light module or a newer version of your light module.
Hope that helps..
My Ride: BMW E60
Model Year: 2016
Btw Jim, I just wanted to point this out to you.
FL_UND_NSW_NICHT_GLEICHZ (Allow High beam and fog lamps on at same time)
is suppose to be nicht_aktiv to work.
Which will explain why it was already set to aktiv on mine and didn't work. I realized this when I pondered why it wasn't working and saw that there's a "nicht" - not - in the entry already.
Just coded it during lunch, and now it works. I imagine if someone is light crazy enough, they can install a HID kit in their high beams and make it... SUPER BRIGHT! Everyone on the road would hate that person though, lol. It's something the bixenon people can't do: low beam, high beam, and fogs all on at the same time
Engine: N54
Just coded it during lunch, and now it works. I imagine if someone is light crazy enough, they can install a HID kit in their high beams and make it... SUPER BRIGHT! Everyone on the road would hate that person though, lol. It's something the bixenon people can't do: low beam, high beam, and fogs all on at the same time![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
Wow - I can't believe I missed that all this time. Sorry for all the confusion - at least there is an explaination for what you were seeing.
I can't edit any of those earlier posts - hope everyone sees this!
Correction...
nicht_aktiv
Hope that helps..
Hope that helps..
I will anounce you with their answer.
