NCSExpert Code Mods
Old 03-21-2011, 10:29 AM
  #171
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Originally Posted by Sublime
Oh, and we should also add to the google doc that turning off the amber eyebrow is:
LMA
SIDEMARKER_US
nicht_aktiv
I did this out of curiosity and it turns out I like the way it looks better.
Just to goof around I am going to turn the eyebrow into my front turn signal...might look awful, but fun is fun.
Haha, I thought this was known already otherwise I would have noted it when I turned it off for two members over a month ago.
Something interesting regarding this though. For people with LM2, if you enabled welcome lights, the eyebrows will still fade on. If you do want it off entirely, it has to be disabled entirely in LMA module.
Old 03-21-2011, 12:14 PM
  #172
NoQuarter's Avatar
Engine: N54
I like the eyebrow. I was trying to get it to come on with the DRLs like when the switch is on the parking lights.
Old 03-21-2011, 12:58 PM
  #173
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
You mean you're trying to make the eyebrows' be DRL as well?
Unfortunately, I don't think you can with coding, since there's only one entry. Might have to wire it
Old 03-21-2011, 12:59 PM
  #174
BLooD's Avatar
You cant im afraid I have checked as well.
Old 03-21-2011, 01:01 PM
  #175
Ehssan's Avatar
My Ride: Many BMW's
Guys , check the last post of the coding thread ,, i need LM1 trc file ASAP
Old 03-21-2011, 02:33 PM
  #176
Sublime's Avatar
My Ride: 2012 535i M-Sport
My eyebrows are now turn signals, haha - had to wire it of course - and they are not nearly as visible as I would like when the DRL or headlights are on (I saw that coming).
Wheres Bruce? I wonder if you could build me a couple modules that modulate voltage when the turn signal is activated. Kind of how the Audis do it - when the turn signal is on the LED DRL's turn to half brightness. If I could dim my AE's while signaling this may be a mod worth keeping - otherwise I'll keep it until LAPD decides I violated some DOT regulation.
Old 03-22-2011, 12:29 AM
  #177
kreveta's Avatar
Cool! Can you share some pics or even better a video? We'd like to see it. Unfortunately, eyebrows (with the stock bulb) are nearly invisible in a bright sunny day. Did you change the bulb?
And more importantly, is this possible without hard-wiring the cables via NCS Expert? I was told it isn't a few times here but I suspect you've tinkered with the LMA a lot (discovering the 12V angel rings) so maybe you found something related to turn signals?
Old 03-22-2011, 09:35 AM
  #178
Sublime's Avatar
I will take some video in my parking garage before i switch it back.
It is honestly one of the most unsafe mods I've done. I looks fantastic with the headlights off in a dark area - but that's hardly a realistic driving environment.
Old 03-22-2011, 09:48 AM
  #179
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Without getting too off topic, but this is something I thought about doing. Except that I wanted the eyebrows to function normally as it does, but with turn signal activation, it would blink in conjunction with the turn signal and side markers. Unfortunately, I never spent time on it to figure out how it would be regulated.
Old 03-23-2011, 11:05 AM
  #180
kreveta's Avatar
Guys, 12V angel eyes found by Sublime is a hot mod. Maybe we can discuss it in the dedicated thread:
https://5series.net/forums/topic/111...3#entry1320453
Once the settings are confirmed by more members we can add them to the spreadsheet.
Quick Reply: NCSExpert Code Mods
