NCSExpert Code Mods
#91
I would guess that you have tried to use outdated daten files. I would first try and do a coding of the Kombi to put things to default again.
#92
Engine: N54
Please help me, I did the BC_DIGITAL_V and instrument cluster went crazy. It no longer read the tachometer, no longer indicate the tank level, and no consumption. All this happened after I did a software update from BMW dealer. Before the update I've done this and had no problems.Now when i make diagnose with INPA, it say that the kombi has bad data coding. You got a idea?
#94
Did you have a link for expert profile? I have "fisterprofile" can i use this one?
#95
The expert profile is part of the NCS package itself. Fisterprofile will definately not work.
#96
Now, can you tell me please, what file to import from ISTA (and even what version of ISTA) to ncs for not haveing the same problem next time i want to code something?
Thank you verry much for your help.
#97
The info is widely available if you do proper search.
AFAIK latest version of ISTA is 2.40.0. From the SP-daten-E60 folder:
or you can run/execute the batch file 'laden.bat' from under the 'daten' sub-folder.
GL!
PS: For you own safety study how 'laden.bat' file work by looking into the content of that file.
Code:
all .ipo files -> \ncsexper\sgdat all daten files -> \ncsexper\daten\E60 all .prg files -> \ediabas\ecu
GL!
Ok, thank you for your fast answer. I thinck i don't have to make other modifications to xepert profile, just read end recode the combi.
#98
Would be great to find out how to map the custom secondary steering wheel button to "MDrive" (changes the hud from M-View to standard, like in M5).
http://www.bmw.com/com/en/insights/t...es/mdrive.html
#99
Engine: N54
http://www.bmw.com/c...les/mdrive.html
Seems like that should be possible since we lose that button out of the menu when we code for MDrive.
I vote that Dominik figures that out for us!
While waiting on the parts for your SAT retrofit you can entertain yourself with this
