NCS EXPERT: Error in CABD ! ......HELP !
My Ride: Bmw E60 530i 2004 Jet Black sport package on Linea Corse 19" Lc818 Saphire Black
Hi everyone !
I'm a beginner in all this coding thing..
After following the NCS_DIY.PDF
It was now time for coding the digital cluster for a try.
After doing a backup and restarting NCS as it was written on the pdf
I clic on read ECU and I receive this error :
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash3/562762_10151505608030457_857295456_23752932_495954198_n.jpg)
How can I fix this ?
Thanks !
Thanks !
You're doing something wrong. ensure that you setup cable correctly and so forth and that you can communicate with INPA. Plug in your cable and close all programs open. Load the FSW PSW MAN profile then F1, F3, Back.
I see you were able to see your VO above so you're probably there. You need to read the KOMBI and then change the settings and upload it back to KOMBI
Sorry for all this questions, lol I received the cable and software V41 that you've told me to buy achtung last monday,the package seems complete, but I'm new to all this ! just for example, it took me 3 1/2 days just to install all this, and yet I'm not sur if I did no mistake during the install, I think not, DIS, SSS progman and INPA can connect to the car, but it gives me a lot of pain, just to understand how it works
![](https://5series.net/forums/public/style_emoticons/default/bashwall.gif)
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Simon should be of some help on this topic.
AchtungE60, I am also getting the same error as tgm001.
I'd highly appreciate it if you can spend few minutes... I can show the problem via TeamViewer... PLEASE?
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Hi what is the problem? It is showing an issue with CAS2.C05 file. What are you trying to write to CAS? What are the dates on your daten files. Have you done any official change datum status on this vehicle at the dealer recently? If they hooked it up to ISTA it depends what version they have you may need to update to their version.
Thanks men !
Wonky
04-12-2016 08:15 PM
umnitza
09-02-2015 11:28 AM
