N62 Spark Plug Tube / Valve Cover Trick?
In the middle of a reinstall and bought new spark plug tubes. They are giving me a heck of a time bottoming out even lubing them. Ive tried oil & petroleum jelly on the tube ends and tube sockets on the valve cover. Still very tough and doesn't want to seat. Nothing in the way.
so anyone have a product that works better? I read an article about some Teflon stuff but i couldn't find it again.
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
I had the same problem. I used white synthetic grease. I was not able to push it in by hand. I pushed it far enough to be able to start tightening the middle bottom bolts (just a little bit).
Then I started to work on the top middle bolts. After that I slowly work my way between top and bottom (few turns at the time)
That will push the cover in place.
GL
GL
Update : I found Teflon (PTFE) lubricant in gel form at the local pool supply store. Was just $4 and works great. Very thick so it stays on the tubes. I found that there really isn't a need to lube the lower end of the tube, just align and press in firmly. I also lubed the area where the tubes seat on the valve cover.
Again, do not use Petroleum Jelly as i did initially. It will eat away at the rubber over time. I had to undo and clean all of it up. Petroleum jelly does not like to come off anything. Even with brake cleaner. Lots of work.
My Ride: X5 4.8i
GL
GL
sm123
07-29-2023 03:42 AM
