MTech front bumper installation help
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
I ran into that problem back when I originally did mine. The left and right foam shock absorbers are supposed to be replaced with the M tech ones as part of the retrofit. I put my own parts together when I did mine, so I don't know if it comes in the M tech kit or not. What you want is the M tech version of part number 3 in the diagram RealOEM.com - Online BMW Parts Catalog
Hope this helps.
Hope this helps.
My Ride: 06 550i
Model Year: 06
I ordered the pre-lci retrofit kit from getbmwparts.com last year and it didn't come with new foam. I have heard that the lci kit comes with new ones though.
My Ride: 530I
Model Year: 2005
I actually got my bumper air ducts and projector fogs from a car locally that was smashed from the back but the front bumper was pristine minor scratches on the bottom. I just got it painted and installed but I just touched under the license plate to see if the bolts were there but they werent so I know I dont have the adapters. The sad thing is I know the guy I got them from would had just given them to me if he knew mine didnt already have them. I found them and the foam on ECS Tuning so will eventually order them. I want to try to cut the foam first but I'll buy it if I dont like how it turns out. With all this info plus the Umnitza Video I should be fine.. To bad its raining this whole weekend
Thanks guys
Thanks guys
My Ride: 530i
Engine: M54
yep, that and the M Tech fender liners aren't in the kit. BMW wants you to just trim the existing parts to fit. I think they even give you the measurements to trim the fender liners.
socale39
09-05-2023 08:30 AM
chadillac2000
42
09-13-2017 11:15 AM
blackstarr
03-05-2015 04:54 PM
