Logic 7 with aftermarket amp Write up
(Must read too)
https://5series.net/forums/topic/116...market-subamp/
Bought this online for $20
I ground the black wire with the amp ground and i got a extension for the positive and tapped it on the red positive wire
for the Remote part i got a long yellow wire that connect to the trunk loc directly to the amp (White/purple is remote)
The brown/white is the negative output and red/blue is the positive..Tap the trunk loc input wire into the logic 7 amp
make sure you sand down where your going to ground your wire
Wonky
04-12-2016 08:15 PM
bestofthebest
03-28-2016 02:47 PM
bestofthebest
01-05-2016 07:47 PM
Bogdan7
09-23-2015 11:40 AM
