LCI Center Trim and Buttons (on either side of the ashtray)
Old 01-05-2012, 03:13 PM
Sublime's Avatar
My Ride: 2012 535i M-Sport
On my journey to copy everything I like, but refuse to pay retail for on the 08+ E60's, I have acquired many random parts. Most exiting was the complete set of brushed aluminum trim from a junked 2008 M5 (RIP). I had to buy the buttons on either side of the ashtray to match the specific features in my car - and it is getting closer to install time. Since I will be keeping the 550 longer than originally intended, I am putting the HUD back in soon - and while the dash is out I will be making the change to a LCI center console. I bought the cage that houses the CCC and IHKA, I just picked up a set of modules that will now control the buttons in the dash including all new plugs, wiring and connectors. I have studied the WDS diagram for the LCI's and am almost ready to change the way I interface with the LIN-bus.
I just wanted to know if anyone here has undergone this project before to see if there is any practical advice aside from correct wiring and coding. If this goes well, the next project will be to find an LCI transmission to match the new style electronic shifter I have sitting in my parts bin.
Thanks in advance for any and all input!
Old 01-07-2012, 03:35 AM
bruce_miranda's Avatar
It has been done and confirmed to work OK. You need a button module as well. Most problematic is finding the latest wiring diagrams for the LCI. BMW stopped doing the WDS dvds.
Old 01-10-2012, 02:20 PM
Sublime's Avatar
So far I have both buttons and:
61319183233 - ECU for switch in center console
61319138969 - Electronic driver circuit, cent. console
I ordered the connectors, socket terminals and wire. I made all of the pig-tail harnesses for each component I have purchased so far - and as you said, WDS is not easy to hunt down.
(ECU/CONNECTORS): http://www.realoem.com/bmw/showparts...29&hg=61&fg=35
(BUTTONS): http://www.realoem.com/bmw/showparts...73&hg=61&fg=35
So far I have only found the following for wiring information:
http://wds.spaghetticoder.org/en/svg...5770.svg?m=e60
http://wds.spaghetticoder.org/en/zin...610001-K07.htm
I will keep looking...
Old 01-13-2012, 07:07 AM
pradden's Avatar
My Ride: 02/2006 525i Titanium Silver Metallic Manual 6-Speed
Good Luck, can't wait to see the results! Take Pics too!
Old 12-10-2012, 01:40 PM
maniac005's Avatar
(ECU/CONNECTORS): RealOEM.com BMW E60N 535i ECU for switch center in center console
(BUTTONS): RealOEM.com BMW E60N 535i Switch center, center console, right
SP0000025770 - WDS
WDS Wiring Diagram System
I got all the parts as well but i am stuck on the wiring and connectors. The link from real oem i believe shows the male connectors with the modules. I am assuming the modules go under the glove box, as per the WDS diagram, must be a pain to locate re-route the wires.
Did anyone make a writeup on this?
Old 02-02-2014, 08:04 PM
Headtech's Avatar
My Ride: BMW E61 530d - 2004
Has anyone go further on this retrofit? I boght all the stuff and I'm stuck with the wiring...
Old 04-08-2014, 03:58 PM
zino's Avatar
My Ride: BMW E60 520I M54
i am at it right now
Old 04-10-2014, 11:30 AM
zino's Avatar
Here is the wiring diagram for the LCI. I am also doing this mod right now. Wo already got it working?
Old 04-29-2014, 02:04 PM
zino's Avatar
Just finished this project. Workst perfect. It's guite some work but the result looks so much better.
Before:
After:
Old 04-29-2014, 02:05 PM
zino's Avatar
looks quite messy now. photographed in dark garage. Need to clean up the car, take some better shots during daylight. the correct gear selector trim surrounding is on order right now, but im happy with the result
Quick Reply: LCI Center Trim and Buttons (on either side of the ashtray)
