L.E.D. Resistors
My Ride: 2006 550 SMG
I have just installed the led taillamps from auto-gym. They look great and took 10 mins to install. Problem is that the tailamp and the flashers are still normal bulbs. I found the right leds to use, but i need resistors. Anyone know what kind of resitor I should use when replacing #3 and #1 bulb with leds? Both use same style leds 1156.....(6ohm 50 watt?)
Thanks
![L.E.D. Resistors-post_1_1128344634.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/24416d1482364514t-l-e-d-resistors-post_1_1128344634.jpg)
Thanks
![L.E.D. Resistors-1156_pt_a_wm.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/24417d1482364514t-l-e-d-resistors-1156_pt_a_wm.jpg)
For the 21 W bulbs use 10 ohm 20 W; for the 16 W, use 12 ohm 20W. In theory these are standard values, but the 12 ohm resistors may be a little difficult to find in high power versions; try with 10 ohm (or make a "12 ohm 20W" resistor with 1 x 10 ohm 10W in series with 5 x 10 ohm 2W in parallel).
AFAIK you do not need resistors for the turn indicators, as these are not monitored by OBC
Thanks for the info.
If i dont use a resistor for the turn signals, they will flash fast as is a bulb was burnt. I am also confused because das and other members had posted that for the turn signals to use 6 ohm resistors, so i was thinking to use the same for the tail/brake lamp (#3) since it is the same wattage. Any suggestions anyone????
Ah - OK, so the blinker uses the load as part of the oscillator. Sorry - I had assumed it was fully self contained...
Then you can either put in a 4.7 ohm 50W resistor in parallel to one bulb each side (where there is space around it - it will be HOT!), or replace each bulb as above (i.e. front/rear = 10 ohm 20 W, side = 39 ohm 5 W).
A 6 ohm resistor - if you can find it; AFAIK it's not a standard value for 5% tolerance resistors (4.7 or 6.8) - will provide an equivalent load to a 24W bulb on a nominal 12V voltage.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
Do these look like the correct ones:
http://www.eautoworks.com/html/ord-Light~b...lbs-1-33226.htm
Thanks
Thanks
Yep - they'll probably work OK (Assuming the LED lights draw about 10W of power in all). You'll need one per side. If after fitting these it is still blinking frantically, you can add a 10 ohm 20W in parallel.
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
guys I like this kind of addiction so keep us posted how you managed, my concern on No.3 bulb is this lamp was design to have the look of a nice LED but not the function, I am talking about the E60 OEM Hella made for BMW, then this was "copied" for creation of our LEDs. So the place where you would like to place LED bulbs I am afraid the lamp's stucture is not designed for that, no crystal look.
But I trust you so show it us, that you are right and I will say
But I trust you so show it us, that you are right and I will say![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Just ordered 4 resistors, 2 amber leds and 2 red leds. When I get them I will post results
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
I hope I ordered the right LEDS, I got light tower II 1156 for brake/tail lamp and the same for turn signals but in amber
umnitza
09-02-2015 11:28 AM
nigxdoof
27
11-19-2007 06:30 PM
rjcastr
10
10-14-2006 04:23 AM
