Installing Hood/Trunk/steering wheel and center cap emblems. Need Adv
My Ride: 530i sport package - endless possibilities ahead!
Hi Everyone,
I just got an E60 530i and i ordered some carbon fiber emblems for the hood/trunk/steer wheel and all 4 center caps.
I was wondering if you guys had any tips before i get started? or if you know of any you tube vids/threads explaining how to?
thanks in advance!!
thanks in advance!!
for the hood and trunk, you can take a flathead screwdriver (maybe 2) and wrap the tips with a microfiber towel. you will need to try to get underneath the roundel and pry it off, aiming for the 2 prongs on each side (as seen on the aftermarket roundels). some prefer to use painter's tape and tape off the area around the roundels for extra security. as for the steering wheel, it should stick on top the existing steering wheel roundel.
Model Year: 2010
Beware of much dirt trapped under hood Roundel, use microfiber and detailer spray as you work. Do not apply pressure onto paint surface while removing old Roundel.
Installation video from JLeviSW:
http://www.youtube.com/watch?v=HjMoJxzPUH0
Suction cup is also available from Harbor Freight, item #46900.
My Ride: 530D M Sport E60, media pack, bluetooth, pro nav system
Also if the thought of using a screwdriver anywhere near your paint work scares the crap out of you (although it does work) try using an old credit card down either side (3 o'clock and 9 o'clock positions) and gently pry it off, thats what I used, worked a charm
TexaZ3
05-06-2015 09:54 AM
kane1111
04-10-2015 04:40 PM
